Boost Fooler Not Consistent
Old 01-12-2007 | 09:58 PM
jb903's Avatar
Ok Put The Boost Fooler On The Truck And It Sometimes Will Give 25lbs And Other Times 40lbs. If I Roll Into It Slow It Brings Up The Big Boost But Nail It And Low Boost. Any Ideas??? Im Ordering A Sps62/14 This Week And Dont Know How To Control Boost With That Turbo. Any Help Would Be Great.
Old 01-13-2007 | 04:47 AM
973604x4's Avatar
Assuming this is the Quadzilla Boost Fooler, check the MAP sensor connection and use dialectric grease. If you still have problems, call Roark at Quadzilla on Monday. 817-306-2444
sps62/14.....I have one....also called a SPS6280...same thing.
Industrial Injection sells a fooler for the turbo end of the sensor to keep the ECM happy....this keeps the ECM happy but not the MAP sensor. You will still need a boost fooling box (or a Quadzilla Boost Fooler) to prevent overboost codes while using your Crazy Larry programmer. There is a manual wastegate on the turbo but i don't see any need in messing with it yet in my situation.
For me, the Scary Larry adds a bunch of fuel...and the Quadzilla XZT adds some pressure and does boost fooling for me. it works together beautifully
Killdmycobra
11-12-2010 06:15 PM
Big Blue24
17
04-21-2008 05:08 PM
Rollin' Smoke
23
06-26-2007 10:04 PM
salvagesavage
02-24-2007 09:04 AM
Palmetto_kid
01-16-2004 03:21 PM
