boost elbow
boost elbow
I need a boost elbow to use my boost fooler on my 03 and i was wondering if i put those on but decided later on to take the boost fooler out will the boost elbow set any codes or screw up anything since the fooler wouldnt be on anymore
Your stock elbow is a brass elbow with a fixed size opening. This allows boost to ~ 24psi.
An aftermarket elbow usually is designed with a set screw that allows adjustability. The more it's screwed in, the more boost is allowed to build. These come set at ~ 28 - 30 psi before the wasted gate opens. Adjust out, less max boost.
Run both of them. Keep the boost fooler in so the ECM wont cut back on any of the fueling when it sees 25+psi of boost. The elbow will help to build a few more pounds of boost to help keep the egt down a bit.
dodgediesel
14
12-14-2006 09:54 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
