Biggest Tires On Dually??
Whats the largest tire you can run on a 2005 Dually QC without a spacer in the back? I want a more aggressive tire, slightly larger tire but dont really want to run a spacer but I do like the look of 35s on a dually. Any tire recommendations such as size or brand would be appreciated. Pics are good too. THank
HotRod
HotRod
I have Cooper S/T's 265 70 17 on the back and they have 1/4inch clearance. I have a Toyo Open Country A/T 265 on the front and I could probably fit a 285 70 17 of this tire with about 3/8 inch of clearance on the back. It totally depends on the overall width of the tire which varies alot from tire to tire. You don't want to have to run 80psi in an aggressive tire just to get them to fit as they will wear quickly and scallop and ride like crap. I run 60psi in the front and 45 to 50psi in the rears and they are wearing perfect. I have over 60k miles on the rears and I had tons of power and drag raced them all summer...they are lasting way to long and they still have tons of life left in them....maybe another 30k at least. ks
I have Pro-comp A/T 265/70/17's on mine. I run 75lbs up front and 45lbs in the rear. I've got at least 1/4 clearance between the duals unloaded but anything over 2000lbs of payload and they rub. I do have a set of 8mm spacers but they are just enough to push the outside rim off the centering shoulder and so a perfect balance is questionable. I only used the spacer for a few months because of this. I'd recommend running a higher pressure or sticking to a narrower tire if you do plan to carry much weight.
I've been drooling over BFG's but even the BFG 265's look wider than my Pro-Comps and I'd have to run that spacer.
Ok looks like im leaning toward 35s with a spacer for the rear and possibly a level kit for the front. How much rub can i expect up front without a level kit. Wont be doing any off road stuff just the occasional curb to jump . Thanks
HotRod
HotRod
Why would tires with full pressure wear like crap. I can see how they would ride rough, but it seems like tires with less pressure would have a larger contact patch and thus cause more rubbing, and more wear?
sakisaki400
23
12-31-2006 10:17 PM
RedRam410
10-27-2006 03:25 PM
ridofpwrstroke
09-19-2006 08:55 PM
deere nut
06-16-2006 04:05 PM
1baddually
05-15-2006 06:29 PM
