bigger tires on dually?
I want to put 315's on my dually,and was wondering if anyone has done it.I know I will need a spacer,the question is how much of a spacer?
Re:bigger tires on dually?
In order for the 315's to wear properly, you will have to go to wider rims. The stock rim are only 6" wide. The minimum rim width of BFG 315's is 8.5" rims.
I just wish other tire manufactures made tires for the dually's. I don't really trust Goodyear! :
[quote author=Dr. Evil link=board=49;threadid=23377;start=0#msg219532 date=1070807217]
Big Bob - thats not true.....
Ive seen a dually on 315 BFG's with stock rims and a spacer....
[/quote]
Dr. Evil,
The key to my post "to wear properly"! You may want to check the tire manufactures recommended rim width.
So my statement is TRUE! What you have seen and what is correct are two different things. ;D
[/quote]
Dr. Evil,
I don't care if they wear properly,because my 03 only had 20,000kms on it and my goodyears were over halfway gone.Even if I get the same mileage out of the BFG's,I'll be happy.I got over 80,000kms out of my last set of BFG's,on a 2500diesel with the same mods.They are a way better tire.
[quote author=Steevo link=board=49;threadid=23377;start=0#msg219565 date=1070815747]
I don't care if they wear properly[/quote]
I should have said "thats not necessarily true" And Im well aware of the rim width recommendations as Ive been toying with putting 315's on my 2500.....lots of guys put them on stock 8 inch rims....may not be recommended, but it is done.
Sorry for the confusion.
Top's Younger Twin
Those tires from the factory are junk. I have just over 10,000 kms on mine and they look half worn! I never liked Goodyear. I want to go to a low profile 14 ply Michelin with 10 bolt adapters and 19.5s and get away from the 17" stuff.
[/quote]
[/quote]
Swampers have a 34.5 X 10.5 that just touch with the stock wheels. YOu will need the two inch leveling kit thou. They have a great loda rating aswell.
JT
JT
If you actually work the truck and rack up miles go with the rickson wheels and commercial tires.
Our big trucks at work have tire problems that are few and far between despite the heavy loads and miles put on them.
Top's Younger Twin
thats the place.
[quote author=Dr. Evil link=board=49;threadid=23377;start=0#msg219685 date=1070831308]
Scotty, have u checked these guys out???:
http://www.chromewheel.com/
[/quote]
[/quote]
OK
what about the average dork that doesnt have a ton of loot to play with and just wants a little bigger tire?
I had 255 85 16s on my 02
is there something available that is close to that size in 17 inch?
[quote author=Agades link=board=49;threadid=23377;start=0#msg222259 date=1071186774]
is there something available that is close to that size in 17 inch?[/quote]Wouldn't 265/70 17's work ok? (they're a little wider, but shorter than your old 16s) I'd be concerned about tire rub in any event.
05-29-2009 10:24 PM
ram013500
02-09-2009 10:35 PM
sakisaki400
23
12-31-2006 10:17 PM
03whitedually
16
11-11-2006 05:54 PM
