Bigger than a 315 or a 35.
Just curious is any body running anything bigger than a 315 or a 35 inch tire on there 3rd gen truck? I have 4.5 inch suspension lift and 3 inch body lift and I'm just curious as to what might fit. I know a 37 will fit but I was wondering about a 38 or a 39 incher. Thanks
Depending on your backspacing and rim width...37's will not fit./ Search and find many many threads. In short, I played around with it and gave up on 37's and settled for 35's with the same lift as you. I needed more backspacing and fender trimming...either of which I could not do at the time.
Sorry..missed reading the body lift. I would think the 37's would fit...but still try to keep the rim tucked in near stock specs to make sure they don't hit under extreme flex at steering lock.
hotdram
02-04-2005 08:32 PM
cumminsho2500
09-12-2003 07:50 PM
