BHAF + torque tube finally done
I got around to completing my intake project today. I've only driven around the block but the amount of noise over stock is drastic.
Exhaust work will be next.
I used the following hardware and copied others work I'd seen here and the filter is touching nothing but the clamp.
2 rubber 90's
1 aluminzed 90
a bit of 4 inch aluminized tubing
a bhaf from fleetfilter.com w/outerwears
some 4in t-bolt clamps
1 10.5 t-bolt clamp
1 bracket I had lying around/w bolts
2 rubber 90's
1 aluminzed 90
1 10.5 t-bolt clamp
Hello
That is a sweet looking job you done.
Can you either post or PM me the part numbers or your source for the tubing and hoses?
Thank you
See Ya
Chris
Thank you
See Ya
Chris
Looks GOOD!
I just got done with mine on my 2nd gen about 2 weeks ago and I have been thinking of a way to build a "torque tube" recently. Where did you pick up your rubber elbows from? Oh and clean install.
http://store.airflo.com/rubber-hoses---clamps.html
Originally Posted by SuperDave4x4
Looks GOOD!
Thanks for the kind words everyone. The one tough item for me to source was the 10.5 in. t-bolt clamp. I had trouble finding any that big because I was searching truck related resources. Eventually I wisened up and searched marine resources. You'll find plenty to buy online if you look at marine applications instead.
looks awesome...i think im going to give it a shot....what was your total build cost? Do you have the exact length needed for the 4 inch straight section of pipe? Thanks, Jason
Originally Posted by 2500WHITERAM
Is it possible to use the stock snokel? I bought the correct paper element, an I will be damned if i can get the two to fit together!!!
Cheers
Bekim
see my gallery
