BHAF for 2005
BHAF for 2005
How does the BHAF compair to the other air intakes and what size parts and where do i get them. Thanks for any input. oh its for a 2005 CTC.
2005, 3500, 4x4, SLT, 6 speed,
Thats MR Hoss to you buddy!
I don't know how it compares to other systems, but you can get all the parts you need from Air Flow Systems.
You'd need the filter and nothing else if you want to stick with your stock tubing. The tubing will slide right over the filter opening. If you're interested in changing the tubing then you'd need some other stuff as well.
Tire Hater
HEH! MCummings and I made an intake for my truck, and for several others. All you need is a 4" peice of steel, maybe 6" long at most to connect to stock rubber hose to the filter.
Originally posted by BigBlueDodge
nickleinone, where did you get that pre-filter that you put over the BHAF ?
BCarmicle
09-14-2005 07:27 PM
