beta 4.2 or new TNT?
The TNT softwares are intended for use with certain modifications. If you don't have upgraded cp3s and turbos you may not be able to use the upper settings and need to throttle back. I would think someone would be able to use TNT on a truck with stock cp3 and injectors with some of the intermediate settings but the tranny would need to be up graded.
I'm running a early stage I cp3 with only 90 hp injectors and can run the highest settings while maintaining 22-24K at the rail. I do keep 25psi feeding the cp3. It takes some tuning but I think TNT can come very close to the beta 4.X softwares. The upper settings may be too much for a stock cp3.
100% agree...i'm sure TnT is fabulous if used with the appropriate mods (CP3, Injectors, Turbo,...)....but to a large extent, it needs these mods much more than the beta's did...so it's not that there's anything wrong with TnT...far from it...i think it hit it's purpose for BIG POWER as is evdinced by the numbers it's produced and the positive feedback it's gotten from the heavily modded big boys...i just think the audience is a lot more narrow than that of the beta's 4.2-4.4 was...because of TnT's need for extensive mods to utilize it to it's full potential.
"If you don't have upgraded cp3s and turbos you may not be able to use the upper settings and need to throttle back. I would think someone would be able to use TNT on a truck with stock cp3 and injectors with some of the intermediate settings but the tranny would need to be up graded."
That's me exactly...have the upgraded trans and fuel pump...but stock cp3 / turbo / injectors...and i can't support level 7 or 9 and if i "throttled back"...the peformance is less than that currently offered by beta 4.2-4.4 on level 7 or 9...which my current mods can and have supported since the first version of 4.4....i need to get the additional mods and try them 1 at a time to determine what is the majical mod that makes the TnT the end all....or if all 3 (cp3, turbo, injector) are needed....saving $'s as we speak....
So posts #12 and #16....stock cp3, but aftermarket injectors...and no issue maintaining rp on level 9....maybe we're on to something.... either of you have aftermarket turbo's?
I can run level 9 rp 4 with no issues. I can hold 22500+ at wot. I think the turbo makes a big difference. I can tell I'm at the border, if I get injectors I will have the mod the cp3 also but right now it runs better than the 4.2 and my mileage is even better so I'm not changing injectors or anything until I need to or I get a heck of a deal I can't pass up.
My truck now prefers 4.2 even over the 4.4 thanks to TCR! I totally agree that the TNT is more mod specific to get high gains, and many trucks act differently to mods. The revo confuses alot of ppl because many don't know where to start, some ppl didn't even want the adjustability, they like the simplicity of having the certain program at tap. I know this is for the better, but it leaves some ppl confused at what they're doing. I'm not bashing, just stating that this could be a reason for some ppls misfortunes with the TNT.
4.2 vs 4.4
So whats the opionions of you modded guys about the power difference or 4.2 to the revo tnt? I did 681 with the 4.2 and have been gone the last few weeks with no internet to keep up with it so am concious about switching to the revo fearing that I cann't go back to the beta's or should I not worry and do it.
Agree the adjustability add a lot more variability compared to just loading a program...but it's not that hard to test out different settings....for instance, in my quest to replicate 4.4.... i tried a ton of diff options, but logically, based upon what i know with 4.4...i focused around
Level 7
Tq Mgmt: 3 (4 if targeting 4.2)
Timing: 2 (aftermarket inj timing...marco stated that's what 4.2-4.4 uses)
RP: 3 (need to try 4, as 3 isnt in the same league as beta 4.x)...i think this may be my missing ingreedient
WG=Off
I'm gonna give rp4 a try today and see if that get's the throttle response / partial throttle behaviou similiar to 4.4
Curious as to what made you now prefer 4.2? I personally like 4.2's agressiveness...but it doesnt get a long with my trans (holds shifts to 2200rpm at light throttle)...so i use 4.4....
Level 7
WG=Off
Level 7
WG=Off
RP's definately a little higher with 4.2-4.4....on 4.4 i'm at 9k idle, 17-19k cruise, 25k wot....she sure spools great....
Loading TnT right now to test Level 7, Tq M 3, RP 4, Timing 2, WG off....we'll see what she does....hopefully RP4 = Beta like spool and response...
