Best way to get injectors out?
I have heard that some people have simply pulled them out, but of all the ones that I did, I used a small pry bar and gently tapped on it with the tip under the lip by the solenoid.Put a rag on the edge where the valve cover sits on so there's no scarring.
The trick when using a pry bar is to pull the injector towards the bar while prying up.
Example. If the bar is on the injector at the 6 o'clock position, you'd put your hand at the 12 o'clock position and pull towards 6 o'clock while prying upwards. Very little force should be necessary.
snowmanx
05-23-2010 09:18 PM
FRANKIE
08-05-2003 08:05 PM
FRANKIE
08-05-2003 12:55 AM
