Best upgrade for towing performance
Hi im new to the forums and i haul rv's for a living i currently have a 2004 ram 3500 turbo diesel and i was wondering what upgrades would provide me with the best towing performance(save gas,extra power, better handling)
The truck tows fine but i just want to get the most i can out of it.
There alot of upgrades that can effect different aspects of towing. If I had one thing to do I would put a tranny in. It gives you piece off mind and will be better overall situaton. 2nd I put an exshaust brake in and airbags. These upgrades are very pratical now as far as haulin *** programmer, turbo, water meth, fuel pump, injectors these upgrades will give you the ability really move.
Originally Posted by gablekevin
thanks for the info what kind of performance gains can i expect if i take out the cat and muffler and maybe just use those glass mufflers
Gains
here are the gains over stock with Silverline Turbo back (no cat) Volant air box Cool twist Intercooler took 3 pulls to get this 11 H.P. 22ftlbs tq over the bone stock truck when I got it I dynoed it, hows that for almost 2Gs? it did lower the egts down quite abit and I knew that going into it, on the 05 you need a good intercooler because they have the junk tanks on them. But now when I turned the Edge on the power it made was more then what they claim. I do owe Big Thanks To John and Scott at Floor it Diesel for the work they did on my Trans and CP3 pump. John you are the man
1 Post
get some gauges , either straight pipe it or get a flow thru muffler,and put a mild box on it not over 75 hp and it will tow fine and still get good mileage with out having to spend a fortune, unless you got the bucks. my .02
With the 3 performance mods in my sig I have picked up 2 mpg both empty and while towing our 5th wheel. My EGT's are down about 150* from stock even with the XZT.
You might look into a downloader that way if you ever need to take the program off easy you can. They are adjustable on the fly and like others were saying i would go with gauges of some sort. Keeping an eye on EGT's, transmission temp, induction temp, and transmission slippage is a good thing. Not to mention adding a couple miles per gallon never hurt anyone.
jmd4993
07-15-2013 11:02 AM
oldblue93
07-20-2010 01:34 PM
2003Ram
03-26-2008 08:58 AM
LilBigd02
02-28-2007 08:31 PM
deere nut
08-16-2004 12:50 PM
