best street turbo for 550 rwhp
Old 04-12-2008, 06:22 PM
diggity dodge's Avatar
The title says it all let it fly as to what and why I know I aint even close yet but thats what im shooting for.
Old 04-12-2008, 08:05 PM
CoolumConst's Avatar
I just taked to II and they said the Silver 64 would work good for my set up, even at 7000' elevation. With the G-56 I think it would spool good.
Old 04-12-2008, 08:16 PM
Hillbilly Delux's Avatar
silver 62.. super quick spool
Old 04-12-2008, 08:36 PM
mipapa's Avatar
Hillbilly, Do you tow with your Silver 62? If so how does it do? We have pretty similar setups and I've about made up my mind on the Sb 62, but I want to only do it once. Thanks..
Old 04-12-2008, 08:44 PM
Jetpilot's Avatar
I would go with a SPS62 or the HTT 62/13SS. The larger turbine wheel in the Silver series is not needed on a small size compressor like a 62. Also the 73mm turbine is not a LP wheels thus a lot of the gain from the bigger wheel is negated. Spoolup will be better (especially at 7000 msl) and egt control is comparable. I have run all of these turbos, I like the SB but I am not sold on the Silver 62 or 64 series.
Old 04-12-2008, 09:27 PM
c-hawk's Avatar
I'm with Doug. HTT 62/13ss would be my choice.
Old 04-13-2008, 12:15 AM
desertchecker's Avatar
single turbo in a 62 & going for 550 hp
that would be a II silver 62 , it's the king of 62's
guys have made over 600 hp with that little turbo, thats a bad *** turbo
Old 04-13-2008, 01:14 AM
Big Blue24's Avatar
Best turbo is the smallest one you can stand to run with egt's acceptable to you. I read all the time about guys that hit 1200 and say, yep, time for a new bigger turbo! A set up that keeps egts below 1200 at all times is oversized and you are leaving driveability on the table. A smaller setup that hit 1400 or so would be more ideal for street duty.
In a stoplight war, he who spools faster is king, not he who makes the most HP above 3000 rpm.
Old 04-13-2008, 04:48 AM
Sinbadd's Avatar
TDR had a write up on the Garret bb turbo and had nice results. Guys on the second gen forum are starting to run these and have good things to say. I have not heard anything from anyone on this forum yet but do some research, It seems like a good choice.
Old 04-13-2008, 05:52 AM
Hintz's Avatar
MPI twins w/ stock turbo
Old 04-13-2008, 08:46 AM
Brian Lent's Avatar
I think the HTT 62/12/65. I have more than 550 and for daily driving, it keeps it in check. It spools way faster than the 14 housings. I've never tried the 13 but like Big Blue 24 said the smaller the more drivable. My brother has a 14 housing with dragon flow injectors, and off the line I get two truck lengths by the time he gets it lit. I tow with egts under control on performance and tst on 1-1.
Old 04-13-2008, 09:27 AM
BIGDAN65's Avatar
i agree, i have a HTT 62/12 and it lights up with the ATS manifold. mine will hit 1400, ck my sig i have done alot of mods just for egt control. i love the way my truck drives around town. a 62/14 would be better for egts. i dont know if you tow but even with the 62/12 i have to spool it to keep egts down and then i am doing 80+. I am considering a snow performance stage 3 to keep me from spooling it so much while towing. i think that would give me a very fast spool up and egt control
Old 04-13-2008, 09:59 AM
trefling's Avatar
save up for twins, you'll like it so much better
Old 04-13-2008, 03:40 PM
nelrod's Avatar
I don't know answer to your question. but I just got an HTT 62/65/13ss and love it. I agree with trefling, however, I am just too cheap to get twins.
Old 04-13-2008, 05:53 PM
rmalone's Avatar
I know with my sps66 everyday driving/cruising egt is much higher than with the stock turbo. I would say that a set of MPI twins with your stocker up top, as was already mentioned, would best fill your needs. However, your probably not wanting to spend that kind of change so stick with a 62 class turbo be it II or HTT, they work excellent as a top turbo in twins also if you ever want to upgrade.
Without doing twins you really have to decide if you want max power or street power. I have no doubt that 0-60mph/30-60, my truck would be quicker with a stock turbo versus my 66. Now if I can stage up at the start it would be a different story of course. A whole lot of guys have went from stock turbo to big single and worked their way back down to the 62's or finally sold a child and bought twins. My 66 works on the street but to say it is suited to that task or has street manners would be a lie. By the way I have a set of twins ordered from MPI right now, 70k miles worth of sps66 is enough for me.
Quick Reply: best street turbo for 550 rwhp
