Best Stand Alone Electronically Triggered Injector
Which of the big three has the best electronically triggered fuel injector? I am working on a project and I need a high pressure diesel injector. Also, which pump is the most reliable?
Thanks,
Mark
Thanks,
Mark
Both the Cummins and the Duramax uses the Bosch CP3 pump and injectors.
The Ford 6.4L uses the Siemens injection system.
Don't know if one is any better than the other.
MikeyB
MikeyB
pressure control/regulation is the job of the fuel pressure regulator valve (FCA).
with a tech 2 (for GM, I dunno what chryslers scantool is called) you can manually control the FCA and a CP3 will make 26,000psi at idle. (although it wont flow a lot of fuel)
for your project you'll need something to control the FCA on the CP3, unless you just want to run max pressure all the time. If you use a dmax injector you will need a high voltage driver with dc-dc inverters of some sort to fire the injector. LB7 injectors run on 96vdc and LLLY's run on 48 volts.
ben
SOhappy
04-20-2008 11:10 AM
6.7megamax
10-22-2007 04:55 PM
stealman
23
11-15-2006 07:00 PM
Capp35
12-21-2005 10:46 PM
