Best stack with a banks six gun/ speedloader for 03
gettin a super phat 62 on the way best recomomendations without ripping the banks junk off of it
1 Post
The speedloader advances timing and increases rail pressure, so the best stack will come with something that increases duration only, or advances timing just a little with increased duration.
The Van Aaken C3.2 is a duration only module that works very well on the 03s and may make a good stack.
A TST module with the adjustable timing option so you can turn the timing off or at least turn it down. That would stack well.
A programmer that allows you to turn timing advance off or one that doesn't advance timing very much on the lower programs, like the Bully Dog/Predator/Superchips. Any of those loaded on their lowest setting would stack well as they don't advance timing much and they are super cheap used.
DTR 1st Sergeant
you can stack the smarty successfully. I ran smarty/ six-gun for a fair amount of time. Eventually, you pull it off anyway as the six-gun becomes a limiting factor as the built in safties in it start making you defuel at inopportune times... like when you first depress the accelerator...
I ran mostly the smarty and turned on the six-gun only when I wanted a little more... the smarty feels about 10x stronger anyway.
it was on when i bought it 2 years ago and I said to myself oh well i had enuff fun with my 24v i wasnt planning on doin anything to it. but my turbo just puked so i figured while im at it, thro a little more power on there
5POINT9
06-01-2009 05:32 PM
Sebaruwrx
02-10-2007 02:10 PM
big red psd cc
03-02-2005 12:03 AM
local601
108
05-27-2004 06:21 PM
SuperGewl
01-21-2004 06:54 AM
