Best Electronic Guage Setup
I need some input on an electronic guage setup. Im not a huge fan of the oulook monitor due to its defueling even when defueling parameters are set at their max. I do like the BD X monitor but dont really like the old hatch mark type deal ive seen a few that some of the hatch mark deals dont light up so their are parts of numbers that dont light up. The commander has everything i want EGT, Boost, Trans. Temp., Rail Pressure etc. but i dont really like the look of it if that doesnt sound to wierd. I do like the Ts Performance set i think its called a MPD or something like that however it doesnt do trans. temp. as far as i can tell from what ive read or maybe it does anyone know but i like the look and lighting style it has. Not a huge fan of the recon either. I do kind of like the Edge Attitude not really messed alot with them though will they work without a juice box? Does anyone else have any ideas without having to go with analog style guages, I think ive covered all the guages i know off any suggestions are greatly appreciated.
well my first choice is analong because for some reason i trust them a little more than the others, but since you want electronic, i would lean more towards a quadzilla product before anything else. i just ordered my new rp and fp gauge and its a quad so ill let you know how that works out for me if your curious. everything else is analong though
brett
brett
It defuels 2 and i dont want to run a bullydog programer right now making more power with my current setup. Maybe in the future when we can get the kinks worked out in some stuff ill go back to it. But thanks for the reply.
Ya just realized that about the attitude, The commander is nice but just bulky i guess just not that appealing to me qzilla but i guess im leaning towards using it being that it has all the features that i want anything else out their that i missed?
Works good for on the a pillar with handle. Very responsive.
http://www.dakotadigital.com/index.c...rod/prd367.htm
I have looked at those just not really investigated on them any the one that does egt/boost/temp. can the temp be used in any location(Tranny/Coolant, etc.)?
yes Im looking at intake air temp with my temp sender you can have a setting that flashes the display of lets say boost mines set to flash at 45psi boost only defueling is by your foot on accellerator same for egt and temp been great for a year not a single problem with it and I just put the sender under the hood one small bit of wiring through firewall gromit and a ignition wire
wildcard
16
05-03-2008 08:28 AM
bigragu
01-24-2006 11:16 AM
SilverDiesel
12-12-2003 03:41 PM
