Bent every rod in the block...#5 made a exit stage left.
Old 02-14-2009, 09:26 PM
Howling's Avatar
If you don't mind sharing what other mods are done to the truck.
Old 02-14-2009, 09:30 PM
Topper's Avatar
Wow! That's some serious carnage! Sorry for your troubles but I bet it gets built better then ever!!! Have fun.
Topper
Old 02-14-2009, 09:38 PM
cincydiesel's Avatar
Part of me feels bad for ya and the other makes me only wish I could tell everybody that my truck has enough hp to do something like that.
Old 02-14-2009, 10:27 PM
dodgediesel's Avatar
Originally Posted by joesixpack
Yup, these rods are a bit on the mushy side.....
I'm a stones throw away from the eskimo's....(NE Saskatchewan)......lets on to how DENSE the air was.....
Yeah the other pistons are perfect, 100% not even the slightest scratch in the skirts running 7.5 thou clearance.
Did you guys make it to the NADP Blackout last year in Edmonton?
Old 02-14-2009, 11:39 PM
megacabdad's Avatar
That's amazing that you were able to drive a 1/4 mile after all that happened.
Old 02-15-2009, 07:00 AM
rootercycles's Avatar
Does it have a hemi?
Old 02-15-2009, 07:37 AM
tsm427's Avatar
That sucks didn't you just get it back together? How many miles on it before it let go? Good luck on the rebuild.
Old 02-15-2009, 09:13 AM
DTR Advertiser
Don M's Avatar
I used the cracked cap rods on my engine build. A 12V. They were lab tested to be stronger than all the others. I am now convinced this is incorrect.
Im going to Cunninghams or Woodruff.
Do you have a cam JoeSP?
Old 02-15-2009, 09:16 AM
John_P's Avatar
Dang,.....sorry to see that!
John_P
Old 02-15-2009, 11:35 AM
lmills's Avatar
NOW you tell me that. LOL
Old 02-15-2009, 11:36 AM
joesixpack's Avatar
Don, I'll be needing another H2.......can you hook me up again, turned mine into a 4BT version, .
Sure was impressed with the H2 (were's the heat! cam) hate to mess too much with a good thing, since this is a build with some prototype pistons, got a cam you want throw in the mix?
I know your backed up there like 10 men, but I might need a set of custom nozzles to match these pistons......sent you a email via Rip inquiring about it or at least your opinion on it.
Chris
Old 02-15-2009, 03:32 PM
chrleb1's Avatar
I think Don has seen these pistons before......
I know what you guys are thinking.... and no. We have never used any of these or seen a motor with these.
Why are you going with those pistons? What are the benifits supposed to be? Your piston only broke because of the rod. My motor had bone stock pistons and help up nicely. Do these not expand quite as much?
Old 02-15-2009, 06:15 PM
kruegerlouie's Avatar
That was a good investment in the Cunningham's......
Nothing's like the puke your guts out feeling when you blow a rod out the side.......
I like the 2000HP rating of the Woodruff's LOL I should NEVER touch those....
what kind of price tag is it to put custom rods in a 6cyl? im thinking about building a 6.7 long block for my 06,
Old 02-15-2009, 07:06 PM
joesixpack's Avatar
Your right, the stock piston is a great slug. The pistons all stood up very well. I set piston to wall at .0075 and seems crazy sloppy for a diesel yet not even the slightest scratch on the skirts anything.
"Do these not expand quite as much?"
Thats one reason, these pistons don't expand as much, they have almost the same expansion rate as the cylinder, the original design only had .0028 clearance. They suggest if your putting the screws to them to set them up less tight.
The ability to stand crazy egt's, and even higher peak cylinder pressures.......
Sounds like we cant use water this year pullin either because of people spiking it with meth, so now it will be who can keep from melting down....
Old 02-15-2009, 07:13 PM
joesixpack's Avatar
3-4 grand...ish
And if your looking to go big with the 6.7 I would suggest rods are manditory, I can't say I have experience with the 6.7, but take that same PM rod and throw some more bore at it, I'll bet its hurting at the 800-900 hp level.
I know I read a while back Brown's diesel doing some 6.7 work, not just sure how that all come out....it was getting up there.
Quick Reply: Bent every rod in the block...#5 made a exit stage left.
