Bed Rail Rack + Tonneau
Greetings all,
I'm searching for a Tonneau (preferably folding) option which would be compatible/integrate with a bed-rail accessory mounting system (preferably Thule). ~>
The only option I've found thus far is the Pace Edwards JackRabbit w/Explorer Rails
The rail mounts look as though they may be proprietary ~ only compatible the the PE tonneau and rack mounts.
Any other options in use out there? My searches came up null, except for the PE sys.
ETA ~> looks as thought the explorer rails are compatible with Thule TK1 Tracker kit
TIA,
Dane
TIA,
Dane
tonneau, rail & racks installed
I've since ordered, installed the Pace Edwards Full Metal JackRabbit w/Explorer Rails & dropped my Thule racks in. Getting a (temporary) dash of warm & sunny spring here in the PNW. Took the opportunity to clean & polish the rig and thought I'd update this thread with photos of how the gear looks.
Also put in the PE auto-lock tailgate, which is very convenient and, with the locking tonneau, provides a bit of enhanced security for bed area storage.
If you look closely you might also see the Bel laser transceivers in some of the images.
Anyone needing a tonneau cover that still wants to use their bed rails should look at Agri covers http://www.agricover.com/ mounts to the inside of the rails so you can run anything that would atach to the stake pocket holes.
RJOS
01-06-2008 08:06 PM
dieselnewbie
10-09-2004 02:59 PM
Hummin Cummins
02-11-2003 08:28 PM
