bdpp and reflash question
Old 09-24-2005 | 03:59 PM
blakedill's Avatar
Cool bdpp and reflash question
Had my truck at dodge today to get the A/C warrantied and had them correct my tire size. I don't believe they "relfashed" the computer, but will it screw up my tire size correction if I reinstall the bully dog, and if I uninstall the bullydog will it reset my tire size back to stock
Old 09-24-2005 | 07:21 PM
RamWheelsBy4's Avatar
No it will not change the "Pinion Factor" set to your tire size. I have had mine reprogrammed for a long time. Recently loaded the Triple Dog and unloaded back to stock multiple times with no effect on my Speedo/Odometer.
Old 09-24-2005 | 11:21 PM
blakedill's Avatar
Thanks, that was the answer I was looking for. What all does the pinion factor change other than the speedometer, it seems to run better because of what they did
Old 09-25-2005 | 10:05 AM
STATELINE's Avatar
I beleive it also corrects your shift points for the larger tires
Old 09-25-2005 | 10:34 AM
blakedill's Avatar
Stateline that sounds right, because my od shift was at like 65 mph not sure exactly where its at now but it seems like it was lower on the drive home
mr. ed
05-06-2009 07:20 PM
bsj04
03-21-2007 04:07 PM
PurNLoud
03-18-2007 02:10 PM
hazer04
10-20-2006 12:28 PM
jayrods600
09-15-2005 04:20 PM
Quick Reply: bdpp and reflash question
