BDDL better for 04.5 than 03?
i heard mention that the bddl works better with the 04.5 than with the 03 model trucks is this true?
i have an 03 305/555.....after seeing the video of the 05 burning the tires down, i am curious as to how well it will work with my 03.
i have 5" exhaust and bhaf.......i used to run the edge ez,,,,,,,it was a nice inprovement over stock, but will the bddll be an improvement over the edge?
thanks, chris
thanks, chris
i sold the edge after i had to replace the injector pump, injectors, and turbo....i thought that maybe it was putting to much pressure and maybe thats why the seal failed on the injector pump..... i do not know if that is/was the case.....but i am not comfortable running the edge box on my truck any more......might have just been coincidence.......
chris
chris
Originally posted by Bradleysram
where is this vidieo of the 05 burnin down the tires???
https://www.dieseltruckresource.com/...threadid=58264
I sold one to a guy with an 03 he didnt have a single complaint maybe the first run of production had problems but they did get all the bugs worked out on new batch
If you are having a problem with the downloader, you can contact Bully Dog at the 800 number in the Operating Instuctions and discuss the problem. They might have an update for the software for it. They should be getting mine today to put the new software in it to cover the 04.5 TSB for milage and smoke. I was having flat spots in performance mode and they already had a fix. I am sure they will work with you.
Hello Guys,
I have one on my 03 and it has been great from the start. I have one from first run that Bullydog produced. Packaged with the Outlook it is a great combo for sure
Best regards
Diesel Dan
Best regards
Diesel Dan
RACER47
38
10-01-2003 03:08 PM
Dodgezilla
46
06-18-2003 09:16 PM
