bd turboguard/blow-off valve spring choice?
hey guys , i just received my bd turboguard unit and they include 2 springs w/ the kit. anybody have any input on what spring has worked the best for them?
Using the little red light I set the dials to activate the way I wanted to. Then I swapped out the big spring for the little spring and the 4 washers.
Now it's almost perfect. It will not let the Phat Shaft bark any more. My only complaint is that it blows off a little too much now, even with normal to moderate driving. Any time I have over 15psi and I lift it blows off.
I need to cut the "open" time down so I don't lose as much boost between shifts. Additionally I think I might increase the voltage drop setting a bit.
On edit:
Tial's website shows three springs. I think I'm going to contact Tial to see if there's a spring in between the two included with the kit. I think I'd like a little more spring pressure.
thanks jc. good info. i left the big spring in so i guess i'll swap it out another thing i NEED to find out is where the pcm is on these trucks . need to tap the tps wire . cannot find it!! anybody?
You don't need the PCM, what you're looking for is the APPS sensor. Go to Quad's website and look at the instructions for installing the Quad modules with the APPS tap.
Good pics to use there.
napa 600
01-21-2006 05:12 PM
coobie
12-20-2005 10:41 AM
napa 600
11-01-2005 05:51 PM
