BD Turbo Chart
Old 02-22-2009 | 11:19 PM
  #31
Justice4all's Avatar
Originally Posted by soulezoo
The super B special moves 80 lbs/min. The regular super B does 60.
I actually think 80 lbs/min is optimistic for the Special. It should be more like 75 lbs/min.
I haven't seen many of these running more than 650 HP like the HTT 66's and the Bullets and their wheels are rated at 80 lbs/min.
Old 02-23-2009 | 09:35 AM
  #32
kantdrive55's Avatar
DTR Advertiser
Originally Posted by Big Blue24
These are very close although I myself do not have the equipment to measure compressor flow.
04.5-07 He351cw 950 CFM
03-04 He341 ??? Guess between 800 and 850.
94-2002 HX35/40 Hybrid 6 blade 60mm 910 CFM
94-2002 HX35 800 CFM
HX35 is just over 640 cfm. I dont have the exact number but no way is it 800cfm.
Old 02-23-2009 | 11:56 PM
  #33
Big Blue24's Avatar
I don't know what shaft rpm your numbers come from but I could post several charts made by DSM tuner guys that "over speed" the stock HX 35 and get 55-56 lbs per minute of air. Will an HX35 last very long at 800 CFM, NO!
I will admit that a stock 54mm hx35 at the stock 21.5 psi, is probably down around 640 cfm.
I know of several diesel junkies that have broken into the deep 400 RWHP range with stock HX35's and that ain't happening at 640 cfm. I know of at least one guy that came dang near 500 RWHP with a HX35 with a 21cm exhaust housing. You'd be surprised how much air an over sped turbo will flow.
I think that BD underates the HP potential of it's SuperB, its upper HP limit should be closer to 475 RWHP. I suspect many factors come into play when advertising HP potential such as turbo longevity and marketing in general.
Old 02-24-2009 | 07:32 AM
  #34
tcr's Avatar
tcr
Originally Posted by tcr
What is the super B special in terms of 64/71/14 and extended tips/blade mods are what? DOes it require the adapter/pipe elbow for the intercooler or does it have a 3rd gen housing?
I guess I need to ask again.....Just curious as I'm about to buy a 64/71/13 unless I'm talked out of it.
Old 02-24-2009 | 11:46 AM
  #35
cquestad's Avatar
buy it!!!!!!!!!!!!!!!!!!!!!!!!1
Old 02-24-2009 | 11:55 AM
  #36
Bswope's Avatar
BUY IT MAN!!!
I talked to Chris the other day about mine and he isnt finding anything wrong with it, we actually think I have a bad boost leak somewhere so I ordered a new intercooler boot kit for when my turbo gets back!
Old 02-24-2009 | 01:16 PM
  #37
soulezoo's Avatar
DTR 1st Sergeant
Most companies do the opposite and overrate their turbos... for marketing I am sure.
Old 02-24-2009 | 06:03 PM
  #38
browndg's Avatar
looking to step it up, But I tow a lot and my towing weight is easy 14K some times. Should I just go with the special or the twins ??
I currently like the quick spool with the weight i tow,along with good egt's.
Old 02-24-2009 | 08:03 PM
  #39
Bswope's Avatar
BD Tow twins for the win!!
Old 02-24-2009 | 11:57 PM
  #40
Idaho CTD's Avatar
A "super dave"-- s480 with race cover is about 113 lbs/min.
Back to the BD thread...
About 119lbs/min
Old 02-25-2009 | 02:04 AM
  #41
Ridiculies's Avatar
Browndg, go for the twins, makes a world of difference, I think the Super B really shines when it's used in the twin setup. When it's by itself it can fall short, yet when used as a twin it seems to be perfect. The EGT's will be well in check with the twins also. Contact kantdrive55, Pat will give you all the info you need.
Txwelder
10-14-2005 04:15 AM
Superduty12v
02-05-2004 02:43 PM
Txwelder
01-29-2004 07:23 AM
jet
11-18-2002 10:03 PM
Quick Reply: BD Turbo Chart
