BD trac bar
Old 03-05-2012 | 07:10 PM
justin allan's Avatar
BD trac bar
Does anyone know if there are some better bushings for the BD Trac bar?
I have less than 8k on mine and they are shot allready.
Thanks,
Justin
Old 03-05-2012 | 07:21 PM
jimbo486's Avatar
Par for the course for a BD product.
I'd just replace the entire track bar with one from Carli rather than mess around trying to find replacement bushings and using a BD product period.
Old 03-05-2012 | 07:36 PM
I was kinda expecting this answer
Old 03-06-2012 | 09:33 AM
Hector-BD's Avatar
Vendor - Former Vendor
It's odd to have to replace the bushings so soon, when the bar was installed did you have an alignment done? You have a 6" lift on your truck, our kit says for up to a 4" lift, but it can work with other lifts depending on the drop bracket. What doe's your Rev-Teck drop bracket look like? could it be flexing?
Old 03-07-2012 | 12:50 PM
yes an alignment was done after install.
I have a drop bracket from skyjacker that thing is solid definatly not moving.
with some one inside truck sawing on the wheel it is more than apparent that the bushings in the trac bar are wasted.
the trac bar is acually too long by a half inch to get the axle centered. I can fix that by cutting down the bar. but this bushing thing is anoying.
89dieselkong
02-12-2011 10:06 PM
engcogod
07-06-2003 10:23 PM
powerwagon440
02-02-2003 07:34 PM
perk
02-01-2003 04:01 PM
Quick Reply: BD trac bar
