BD ram x-power
BD ram x-power
A new product out by BD power (not bully dog). It has 4 power levels with the top being 130hp/240lb torque. The hp is achieved by all duration and pulse width, no pressure. They sent me the e-mail newsletter, but it is not on their website yet. I'm not sure how to post it.
Here it is.
The new X-Power Ram module offers new technology in performance for the Common Rail fuel systems on the 2003 and up Dodge 5.9L Diesels, including the 600 series. The X-Power achieves performance gains by altering the duration timing of the injection pulse and not by increasing the rail pressure which has been know to cause fuel leakage and damage. The X-Power also makes for an easy installation by connecting to the factory injector plugs and MAP sensor.
The X-Power Ram module had four adjustable preset power levels that produce increases of up to 130 hp and 240 Lbs.ft. of torque! Click here to view graph! Included with the X-Power module is the Power Dial which gives progressive performance control and comes with a color coded decal.
To make a complete performance installation, we suggest installing the X-Monitor digital gauge pack to let you know what temperatures and pressures your engine and transmission are producing to help prevent any damage. Also available is the Low Fuel Pressure LED Alarm Kit that will alert you if you are developing too low of fuel pressure that can damage the Common Rail fuel system.
Ram X Power
Part# 1054500 2003-2004 Dodge Ram
Part # 1054505 2004.5-2005 Dodge Ram 600
Ram X Power w/3-in-1 X Monitor Combo Kit
Part # 1054500XM3 2003-2004 Dodge Ram
Part # 1054505XM3 2004.5-2005 Dodge Ram 600
Ram X Power w/Boost & Pyro Only X Monitor Combo Kit
Part # 1054500XM2 2003-2004 Dodge Ram
Part # 1054505XM2 2004.5-2005 Dodge Ram 600
Optional Monitoring
Part # 1081130 1999-2004.5 Low Fuel Pressure
Ram X Power
Optional Monitoring
I want to install gauge in my Ram 05 CTD
I read for trans temp the best place is the line between the trans and cooler. I also find X monitor use ECM connection to give trans temp. doest it will give about the same temp or ECM will give pan temp.
thank you
thank you
Originally Posted by OT-OF-Here
This sounds like a re-badged VA C3.2 duration box. Anyone know for sure??
Yes kind of, their new one does timming as well. Looks like it may be a potent box. Digital timming and duration, I may be willing to try it out...if they eventually make it for the early '04's that is..
If we are talking about the Ram X-Power Plus, here she be... http://www.bd-power.com/ram/product....%20Plus&tt=ram
Captain Dean
04-30-2006 11:01 AM
UnrulyNFS
28
06-20-2005 09:12 PM
pwabbott
14
12-20-2002 08:23 PM
