BD Racing Anti DeFueler Installed
Old 10-18-2005, 12:35 AM
abc4yew's Avatar
Guys, I had my RAD installed today. Nice simple unit. Stops the odometer while it is in place. Only going to use it for racing. The truck just flys through the gears with the TC locked...it is unreal. Spins the tires on all three shifts on TST 7/7 but quickly hooks up. In 4wd it would be scary fast. Haven't gotten to try my top speed yet but I know it is well past 107mph. 7/7 tops out at 1480 deg. boost cooler is going in next week then 9/9 is mine. ks
Old 10-18-2005, 05:34 AM
AK RAM's Avatar
NICE! The RAD is almost a necessary addition for us SO auto owners to overcome Torque Management. I just wish it didn't kill ALL the instruments so it would be more practical for every day driving. If you ever run at a drag strip, do a run without it and one with it and you will be amazed at the difference.
Old 10-18-2005, 06:26 AM
Goggleyed's Avatar
How is the RAD any differant from just turning you key back a little while the truck is running? This also kills the instruments and quickens shifts.
Does anyone offer a torque management only solution?
Old 10-18-2005, 06:43 AM
abc4yew's Avatar
Guys, when I turn my key back and hold it I have a hard time manually shifting and my FASS is on accesssories so fuel gets rreallllll short. ks
Old 10-18-2005, 01:25 PM
Goggleyed's Avatar
My FASS must be wired differantly because it continues to run after the key is turned back.
I called BD. They said on the 04' the RAD would only help with top speed (which I don't need) and TM on the 1-2 shift. No TM help on 2-3 or 3-OD.
Old 10-18-2005, 01:57 PM
realsquash's Avatar
What about us 6-speed people?
andy
Old 10-18-2005, 04:35 PM
big red psd cc's Avatar
andy
That's what I was going to ask.......
Old 10-18-2005, 05:19 PM
Well I answered my own question.
It kills the speedo, a/c-blower, radio, but the truck doesn't run any better.
Old 10-18-2005, 05:42 PM
White97GTVert's Avatar
Does it kill all the gauges as stated before or does it just kill the speedo? Seems weird that it shuts off the odo.
Old 10-18-2005, 05:49 PM
realsquash's Avatar
This device doesn't set any codes?
Andy
Old 10-18-2005, 05:59 PM
abc4yew's Avatar
Guys, when on it even blanks out the gear shift indicator The check engine light and all the other warning lights go on the security light stays on and the truck goes like snot. ks
Old 10-18-2005, 06:00 PM
realsquash's Avatar
i don't know if the VSS is a separate sensor on the autos or not but if it is you should try unplugging it and see what happens.
Andy
Old 10-18-2005, 06:33 PM
abc4yew's Avatar
Guys, As far as I know the Sensor is required for tranny shifting pcm and fueling ecm. BD replaces the sensor output with something to keep things running. ks
Old 10-18-2005, 09:41 PM
The ABS, SES, and all of the gagues except the speedo work.
On a six speed, it does nothing for the "going fast" part. Still has the slight lag. Now if turn on the Banks.....yeah it runs like snot.
Maybe it one of those things that works differently in a auto vs. a 6sp?????????
Old 10-18-2005, 10:35 PM
Lord.. With this thing on the market I am sure we'll be seeing a bunch of super low mileage trucks out there.. Sure some people will probably be taking advantage of the fact that it kills the odo.. At least the hour meter should still work... Right?
Quick Reply: BD Racing Anti DeFueler Installed
