BD R700 Twins Video
Old 12-05-2007 | 03:14 PM
kantdrive55's Avatar
DTR Advertiser
Originally Posted by Muddin_dude06
Are you guys going to make these in the 12v/24v setups? How much boost did he make on that run?
We are working on the version that will fit the earlier model trucks. The problem is the heat exchanger. If you want to move it or have a manual tranny the kit except for the downpipe should fit directly on.
Old 12-05-2007 | 03:23 PM
Muddin_dude06's Avatar
What kind of boost was it pushing and at what RPM do they light off at? On his 700hp run what were the EGT's on the big end?
Old 12-05-2007 | 03:54 PM
DTR Advertiser
On that pull I believe it was about 67psi at just under 1400deg. Where they light is always going to depend on fueling. We havent actually done any testing here on them so I couldnt really give you a good answer as to where they would come on.
Old 12-06-2007 | 01:23 PM
DTR Advertiser
There was still some adjustment to make in the wastegate. 70lbs is really what there should have been. That would have brought the egts down a bit further yet.
Old 12-07-2007 | 07:44 PM
sledcrusher02's Avatar
twins
kant drive whats the p/n for the r700 kit?? and any specs on the s300/s400 compressor, turbine housings??? what can you tell us size wise?
Old 12-07-2007 | 08:59 PM
lmills's Avatar
Hey there Rob! I see you have been running the BD intercooler! How do you like it?
Old 12-08-2007 | 12:27 AM
morkable's Avatar
Pat, how would this kit be for high hp trucks? Or do you have anything for a t truck such as mine?
Thanks
Kevin
Old 12-08-2007 | 12:29 AM
O.T's Avatar
O.T
Well... lets just say round two
Old 12-15-2007 | 05:00 PM
pat
any info on the p/n and turbo specs??
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
highrpms
07-03-2008 11:47 AM
DUKCALN
04-10-2008 01:58 PM
kantdrive55
19
10-26-2007 12:15 AM
Quick Reply: BD R700 Twins Video
