BD Power Pup
BD Power Pup
How do you guys like the BD Power Pup? Does it give a nice increase in power and provide a little black smoke? Have you guys had any problems out of this product?
I currently have the Edge Ez but am looking to upgrade to something with a little more power.
Thanks for any info that you can provide.
HUMP
HUMP
the pup works great for me, I have it on the 90 setting , and get 19.1 mpg on the highway, also put the donaldson 41in , and airaid filters system. great performance and nice haze on full acceleration. now if I wanted to make smoke, that is no problems , but very little turbo lag on acceleration.
it works good for me also except when Im towing then it has way to much turbo lag, I did have to send it back for a reflash due to a flat spot on the 90hp setting but the reflash took care of it and bully dog was great with cust. service. I just order a quad box from the dtr store to replace the pup, hopefully the quad does better for towing.
i love mine on 90hp. BD is also awesome with Customer Service. I came up with a problem and my cell battery was almost dead. i called and they put me on hold, so i hung up. called back and told them i needed urgent help and i went right to a rep who fixed me up.
anyway, it pours out a crapload of smoke. i can black out intersections at will. i also have barely any turbo lag at all
Thanks
Thanks guys for all of the information. I think I will go with the BD Power Pup for increasing my need for additional power.
HUMP
HUMP
ive posted these before but here they are
this is a 600/48RE with a straight pipe and the BD on performance
http://www.dodgetrucks.org/home/shauncobb/MOV01813.MPG
http://www.dodgetrucks.org/home/shauncobb/MOV01814.MPG
Unloaded I can't get to 1200 degrees unless I take it to 3500 rpm before I shift and I end up hitting about 1200 when I'm going around 100mph. I get a poff of black smoke at low/no boost but that's it. This is the tripledog on extreme.
Andy
Andy
I took it out to the drag strip on a hot evening in the middle 90's, 25 ft. elevation. full fuel and two guys in the truck , ran 15.22 and EGT topped at 1440 degree's.
My egts are no problem even towing 8000lbs i never see above 1200 empty I never see above 1000 thats on the 90hp setting,for some reason my truck runs real cool no matter what I do to it, been like that since day one and I like it .the pup does smoke real nice under low boost conditions then soon as the boost builds it clears and hang on
Ranger 2/75
03-16-2006 05:07 PM
v-bar
12-24-2004 01:38 AM
glowball
10-31-2004 05:04 PM
sawboywv1
10-14-2004 10:38 PM
