banks six gun owners
Old 11-15-2004 | 12:59 PM
Agades's Avatar
anyone ever noticed a surge in acceleration
say if you slowly push the pedal down
slowly adding more and more power
until all of a sudden it jerks yer neck off
mine does it in all levels
all speeds
not relative to throttle position
is relative to the amount of acceleration you are asking for
like im driving with switches instead of a pedal
I would explain it as at a certain percentage of acceleration it skips from say 60%- 80%
no running in between
Old 11-15-2004 | 01:28 PM
Balls Casten's Avatar
Is it at the same rpm's? The unit does not turn on untill 17 or 18 hundred rpms.
Old 11-15-2004 | 02:16 PM
Agades's Avatar
no
not relative to rpm
only amount of acceleration
you must have the old program
the new one comes on much lower in rpm's
Old 11-15-2004 | 03:37 PM
TUGUM's Avatar
mine does it i just thought it was the added torque, not so noticeable on low settings but kind of anoying trying to stay with traffic
Old 11-15-2004 | 05:51 PM
Agades's Avatar
annoying at the least
theres no way I could ever add injectors to this thing
driveability would be terrible
Old 11-15-2004 | 06:15 PM
Agades's Avatar
I see yours is a 04.5
im courious if theres any 03-04 HO's doing it
I would imagine many wouldnt notice it
if you are given her gunny right after the shift it doesnt do it
im not getting any answers from banks
two modules and both do it
truck stock doesnt do it
neither does a tst pmcr
Old 11-16-2004 | 07:57 AM
Agades's Avatar
a little more info
im not sure exactly how this thing works but if its like the 2nd gens
where the box transitions in at a certain point after using stock fueling up to that point
to me it feels like that is the problem spot
Old 11-16-2004 | 08:37 AM
Agades's Avatar
why do i feel like im having a conversation with myself
Old 11-16-2004 | 11:01 AM
Barrett_Fodder's Avatar
Well ill reply to yourself then...hehe
I have one on my 04 (see sig). I have noticed no stumbling of any kind. I do notice a good jolt when i stand on it but that is just the added power. It is not a jerking or surging action by any means.
Have you checked that there are no codes no the box and that it is set up for your engine through the hardware (product number) and software through the learning? Did it learn the transmission ok? I would check these things then give a call to Banks and ask them. They were more than helpful with me on some stupid questions I had for them.
Good luck hope everything works out well for you.
P.S. How did you verify you have the latest software version installed???
Old 11-16-2004 | 11:10 AM
Agades's Avatar
no codes
learning all went through
box comes with HO program so no learning required for engine rating
Old 11-16-2004 | 11:37 AM
Nothing like that, I can how ever feel the box kick in and the tranny lock up. No problems driving in traffic.
Old 11-16-2004 | 12:17 PM
TUGUM's Avatar
sorry been busy all morning, i did notice yesterday on my way home,the main shock happens between 13-16 hun it kinda feels like the box turning on&off.
Old 11-16-2004 | 01:44 PM
Agades's Avatar
thats where mine does it when cruising and slowly putting the pedal down
but
if you give her gunny a little quicker it will happen at lower boost than that
just got off the phone with one of the higher ups and sounds like it is what I suspected as far as a transition point
it has to do with the way the box reads throttle position with SOME of the manual transmission trucks
he said its an "idle / off idle type switch"
auto trucks dont do it because they read throttle position different
his fix was to put the old program in it , which is less power on the bottom end
THANK YOU CAR NUT 57 FOR ALL YOUR HELP IN THE MATTER
Old 11-16-2004 | 03:18 PM
big red psd cc's Avatar
It by pedal position
They don't want it coming on tooooo soon, or it will cause the truck to smoke alot on take off.
So it lets some boost and rpm build, then it kicks on.
Mine does it too.
Old 11-16-2004 | 08:04 PM
Ramasaur's Avatar
I'm having a problem with my on levels 5 & 6 at highway speeds. This thing bucks like no tomorrow. I've called banks and they gave me a RMA to return it for testing.
Quick Reply: banks six gun owners
