Banks Six Gun
Banks Six Gun
Hi
im chris from switzerland.
i have e 2500 ram cummins 2003 with banks six gun.
i have wen i start the truck the 2,3 fault on the six gun.(thermocouple fault)
but i have not thermocouple installed on my truck.
ha anywone the same problems?
on the manuel if the thermocouple option wen speed loader is installed.
i have not speed loader.
thanks chris
sorry my english
thanks chris
sorry my english
Not sure how to stop the code without the EGT but you should definately get it put in with the speed loader. The speed loader and EGT probe make a huge difference, the six gun won't give you full power without the speed loader monitoring the EGT's.
Hi crobtex
thanks for answer
i have make mail on banks, but no answer.
and the phone number working not from switzerland.
you can make e phonecall to banks and make the questions?
thanks
chris
thanks for answer
thanks
chris
Originally Posted by chrigu
Hi crobtex
thanks for answer
thanks
chris
thanks for answer
thanks
chris
Please you PM me your email address in case I need to have Banks contact you.
Also, I'll see if we can get this thread moved to the "Help" section and see if it gets more response.
Hi
thanks chris
sorry my english
thanks chris
sorry my english
1 turn key on DO NOT START.
2 FULLY DEPRESS the accelerator pedal an release it COMPLETELY. DO this 5 times
3 turn key off, Wait 10 seconds.
4 turn key on fully depress accelerator and release it completely 5 times.
When you do this and you have the Auto ,you will have to follow the process of the Relearn- transmission.
hi twest
I have that already made 1 month ago
than was al ok now the fault comes back.
i have also disconnected the six gun and startet the engine.
and reconnectet the six gun.
same problem.
the problem is wen i start the truck first.
wen i start the truck new the problem is going.
Chris
same problem.
Chris
hi twest
i have the bd-xmonitor with thermocouple you think i can connected the thermocouple parralel with x-monitor and banks six gun?
best regards
chris
i have you found on google earth.
you ship also to switzerland?
best regards
chris
YOu CAN NOT use the speed loader option w/o a thermocouple in place. Take the SL off if you are not going to install a thermocouple, and reinstall the settings w/o SL option.
Can you feel the change when you switch to a higher level,The Dial may be the problem.Also Do no install the SL without installing the thermo-coupler or to any other sensor other than the one that comes with the SL.
hi bbhzx12
bud i can simulate e resitance on the six gun?
the led is solid wen i turn the ignition on.
chris
hi twest
yes i can feel the change.
chris
chris
hi twest
chris
hi
i have not egt wire on my six gun.
the wiring is ok.
corbtex have made e phone call to banks, banks say if not e thermocouple is installed , if was made e bridge on the connecter.
chris
the wiring is ok.
chris
chuckmcdonald
06-04-2004 01:23 AM
deere nut
05-17-2004 10:17 AM
gdh11
03-08-2004 05:45 AM
SuperGewl
01-21-2004 06:54 AM
