Banks Monster Exhaust Owners???
Old 11-04-2004, 01:45 PM
MonkeyLips's Avatar
Just got off the phone with DPP...Thanks for the help! Leaning more and more towards Banks ME. If I could only hear one first hand...any one in the Boise Idaho area with this system?
At a minimum, it would be the Banks DP and a 51" Nelson, but I really don't want to mess with all the pieces parts, then have to deal with a muffler shop and try to explain just what I want...been there before
Old 11-04-2004, 03:35 PM
cquestad's Avatar
Can you weld?
All that you need is a couple of box end wrenches, 4" band clamps, a sawzall, a grinder, and a small welder to remount the oem exhaust hangers on the new muffler...done deal. Maybe a 1 hour job.
Old 11-04-2004, 03:45 PM
MonkeyLips's Avatar
Therein lies the problem no sawzall, though I've been looking for a reason to buy one, or welder (a friend does has a small MIG)...used a MIG welder a few times 20 years ago ;-) Sounds like fun, but those welds wouldn't look very good. I'd probably burn right through the muffer! What takes you an hour would take me days to: buy the parts, the sawzall, borrow the MIG, then try to make it all work. Big job for me Are you going to be around Boise any time soon?
Old 11-04-2004, 04:01 PM
cquestad's Avatar
Yes...the weekend before Thanksgiving. Will do an exhaust on my bro's 4.5.
Family has a steel shop out in Caldwell. If you have all the parts and PLENTY of beer, consider it done.
You will need:
Banks DP
Donalson muffler of choice...I use a 40" (34" body) Donaldson
5' of 4" ehaust pipe
(4) 4" band clamps
Your local semi shop should be able to order all the parts other than the Banks DP. You can get that direct from banks or from DPPI.
Let me know.
Old 11-04-2004, 04:09 PM
cquestad's Avatar
Trebar kenworth
Try there.
Old 11-04-2004, 04:14 PM
MonkeyLips's Avatar
WOW!!! I was only kidding! That is killer!
I'll get the Banks DP, the 51" (if that's okay) Nelson or Donalson, 5' 4" pipe, 4 band clamps, and most importantly, a keg of beer just before you arrive.
What's your favorite brew?
Old 11-04-2004, 04:41 PM
MonkeyLips's Avatar
Okay, the DP, clamps and 4" pipe with elevation for stock tail pipe is on order from DPP. The muffler is on order with Cummins N.W. The beer is on ice!
Old 11-04-2004, 04:44 PM
cquestad's Avatar
Coors Light...
What do you mean 4" pipe with elevation?
My cell is 505-379-2750
I will be driving to Boise Nov 19th. We will most likely do the install on Sat the 20th...in the afternoon after I shoot some ducks and pheasants.
Old 11-04-2004, 04:52 PM
cquestad's Avatar
Oh...one more thing...
you will need a new 4" v-clamp for the downpipe to the turbo. Call DPP back.
Old 11-04-2004, 05:25 PM
MonkeyLips's Avatar
Ah calling right now on the V clamp. DPP said to use the 4" extension pipe that has about a 3" rise to match up the muffler and tail pipe. He said they do it all the time and it works great.
I'll bring my shotgun with the Coor's Light
Saturday the 20th sounds good!
Old 11-04-2004, 05:29 PM
MonkeyLips's Avatar
DPP says to reuse the OEM turbo to cast elbow clamp, but you have to use a gasket between the turbo and DP, which is supplied with the DP, so it sounds like we are covered...
Old 11-04-2004, 05:47 PM
cquestad's Avatar
No...You only need a straight piece of 4" pipe.
There is no gasket between the turbo and down pipe...we want a new V-Band Clamp as well...the stock one is brittle and will bend/brake when removing. Not worth the hassel.
Please make sure the 4" pipe is straight. Order it, the muffler...I would lean towards the 40"...it is not too loud, and the (4) 4" band clamps from Trebar kenworth.
They have a much better price than you just quoted.
Get only the Downpipe and Clamp from DPPI.
Old 11-04-2004, 10:19 PM
MonkeyLips's Avatar
Crap...I was afraid of that. Could not wait for you to reply. Should have called your cell...I will have to call DPP first thing in the AM and change the order.
I cancelled the Nelson due to the cost. Rogers & Bryant has the M090544 51" in stock here in Boise for $89.00. I know that seems like a HUGE muffler, it is. I'm sure the 40" would fit better, but I want this baby pretty quite. Do you have a part number for the 40"? I'll call you on your cell before I get the muffler ordered or picked up...
Old 11-05-2004, 08:56 AM
cquestad's Avatar
Donaldson M085171 ($60 ish at the dealer I stated above)
Exhaust Mufflers Product Attributes
A - Inlet Diameter (Inches): 4
B - Body Diameter (Inches): 8.5
D - Overall Length (Inches): 40
E - Outlet Diameter (Inches): 4
Rated Flow LR (CFM): 1800
Rated Flow MR (CFM): 2546
Rated Flow HR (CFM): 3119
Back Press LR (In Hg): 1
Back Press MR (In Hg): 2
Back Press HR (In Hg): 3
Attenuation (dBA): 8-12
Product Type Description: Muffler, Round, Style 1
Primary Application: OFF ROAD APPLICATIONS
Old 11-05-2004, 10:47 AM
MonkeyLips's Avatar
Thanks! Looks like the M090554 is about 5-7 dBA more quite...I better go with that one.
Attenuation (dBA): 13-18
Quick Reply: Banks Monster Exhaust Owners???
