Banjo Fitting. Where!!
Old 03-10-2008 | 08:37 PM
dslpwr81's Avatar
Not very noligible. Could someone please tell me where the banjo fitting goes on a cp3 pump on an 06 DODGE. Also, is there any pressure that I have to worry about, or air getting in that I should worry about??? PICTURE OF WHERE THE FITTING GOES WOULD BE GREAT!!!!
Old 03-10-2008 | 08:48 PM
Diggie's Avatar
What are you installing? If it is a fuel pressure gauge, then you can install the new banjo on the bottom of the fuel filter. (see pic)
Old 03-10-2008 | 08:50 PM
rip 112's Avatar
What if you have a fass or airdog (canister bypassed) and want to use a banjo fitting for a fuel pressure gauge? Where would it go?
Old 03-10-2008 | 08:56 PM
dslpwr81's Avatar
I do have a FASS 150. So where does it go know. Thanks
Old 03-10-2008 | 09:01 PM
06 DIESEL's Avatar
Gimmie a sec, I will go snap a pic for you
Old 03-10-2008 | 09:05 PM
dslpwr81's Avatar
Sweet. Thanks. I love this site
Old 03-10-2008 | 09:12 PM
06 DIESEL's Avatar
The blue line coming in is the CP3 inlet.
Old 03-10-2008 | 09:13 PM
dslpwr81's Avatar
Do I have to worry about pressure or letting air in their???
Old 03-10-2008 | 09:15 PM
06 DIESEL's Avatar
Nope, just make sure that you bleed the line before starting it, bump the starter with the line barely loose, when fuel starts to bleed out tighten the connection and fire it up.
Old 03-10-2008 | 09:19 PM
dslpwr81's Avatar
Thanks. I will go through it on now. Speaking of pressures, what pressure should there be at idel and WOT?
Old 03-10-2008 | 09:22 PM
06 DIESEL's Avatar
I have a Air Dog 100 and I see 17 at idle and WOT.
Old 03-10-2008 | 09:24 PM
dslpwr81's Avatar
Thanks for the info.
Old 03-11-2008 | 12:50 AM
PRO-NRA's Avatar
Where did you get that 90 degree elbow with a tapped thread? Been looking for a 1/2 NPT to 6 AN with a 1/8 NPT tapped but could not find one.
Old 03-11-2008 | 02:18 AM
RDR's Avatar
RDR
most use 8an.
6an is available from jegs.
http://www.jegs.com/p/JEGS/762951/10002/-1
Tommy93w350
11-16-2016 07:40 AM
Montana Cowboy
03-16-2006 06:22 PM
banks twinram
02-13-2005 05:09 PM
CTDHokie
07-22-2004 06:24 PM
rattle_rattle
03-02-2004 11:39 AM
