Which balancer ati or fluidamper?
Drowningin? what is this? A fluidampnr will help eliminate harmonics which will help the motor run smoother,especially at higher rpm's and it is said to help eliminate some of the noise associated with a double disk clutch.If you are having a problem with one particular gear I doubt this is the solution you are looking for.
getblown5.9
08-18-2007 09:23 PM
tex23455
03-06-2007 09:50 PM
Warlord
06-28-2006 09:47 AM
