Back pressure ? using stocker with twins
Thinking about going with a MPI setup using the stocker in a twin setup. My question is... Isn't backpressure still an issue when running through the stock turbo?
I personally feel it should be externally wastegated. I can't imagine 550hp worth of exhaust flowing through a stock 9cm housing w/o extreme drive pressures. Lots of people on this forum disagree with that statement, though. I'd like to see what the pressures are before committing to that setup...
The stock turbo is still a limiting factor, even if the wastegate is manual it's still pretty small. The only problem you might have is when you decide it's "not enough on the top end". Talk to Nathan, but the impression I got was a stocker up top is harder/more expensive to upgrade than a s300 based turbo. I think it has to do with the plumbing.
Bottom line talk to Nathan and find out, he will tell you straight.
johnny5.9
06-30-2016 01:30 PM
Stainless
69
03-20-2009 12:03 PM
goodeyesniper75
10-04-2007 11:10 AM
