Auxiliary Back Up Lights?
Ok I've been searching for threads on this for awhile and I still cant find what I was looking for.
I thought I saw recently an aftermarket "plug and play" light system that didnt require additional wiring, fuses, etc.
Anybody seen something like this?
Off the bat I must note that Ive seen (and had) the White Knight but didnt care for it much. Anything else out there????
typed in "auxiliary back up lights" in the advanced search box, searched in 3rd gen, including sub folders and got 8 hits. It's a start. The forum's search function works pretty darn good...
https://www.dieseltruckresource.com/...archid=2498130
Recon has a kit on their website:
http://www.gorecon.com/product.php?p...ights&p_cat=46
better off something like kc back up lights. i had the white night lights on a previous truck. they worked-but they were just cheap plastic! after a couple of months- i had to silicone the lights because they leaked. then the lenses started to turn a yellowish color- you get what you pay for- a lot happier with the kc lights.
Doesnt meet your criteria of no wiring, but i used the Defiant Reverse Light Mounts ($30) and 2 5" Hella Rummerized Lights ($18)....price is right, and looks / works good.
i used the wiring from the white night kit and replaced the lights with a small set of driving lights from advance auto parts. i really like the availability of having them come on with my reverse lights or having the switch so i can have them anytime. they work great, i mounted the switch in one of the pre drilled holes in the hitch and drilled a new one for the relay. i will try to get some pics tomorrow. very clean install and lots of light.
B/U lights
Not in your criteria, but I installed a pair of Grote 4 inch spotlights on top of my camper shell with a Tyco 30 amp relay connected to my stock B/U lights as a trigger so they come on every time I put the truck in reverse. I also added a toggle switch so I can turn them on manually at any time especially when some goof-ball tailgates me; one shot from those high spotlights at night and either the character backs off or passes me. They are really nice when loading up my boat in the dark. It cost me about $45.00 and 2 1/2 hours of my time to install.
L8r,.......dogger
L8r,.......dogger
L8r,.......dogger
L8r,.......dogger
I originally liked the idea of the 3 way switch as well for the on / off / auto so that I could have light wether the truck was running or not but also for the tailgaters as well.
The light would give me a second option to run them off my rear. Of course I still really like the trusty old short goose to the skinny peddle. The resulting black cloud seems to send a distinct and undeniable message!
Thanks again!
sam
02-09-2008 11:57 AM
LanceK
06-22-2006 10:28 PM
LanceK
05-26-2006 12:03 AM
texasaggie2005
08-30-2004 09:03 PM
Commatoze
09-11-2003 07:23 PM
