Autometer C2's To Bright
Old 02-07-2008 | 02:42 PM
Hillbilly Delux's Avatar
I tapped my ilumination wire into the one for the heater control lights. I can dim my factory gauge panel almost completely off and there still extremely bright. anybody know what to do to dim them up a bit?
Old 02-07-2008 | 03:15 PM
nelrod's Avatar
Just an idea---mechanical not electrical ---go to a tint shop and I bet they would give you some scraps of whatever darkness window tint you wanted. Be crafty and cover guages and I bet it would look cool. Also, if you did not like it, you could take it off. Also if you have a bud that works in hospital, get some X-Ray film to cover it. I've seen that over license plates. Again, however dark you like. I think window tint would work better though, as it is made to cover glass. Maybe worth a try. Good luck.
Old 02-07-2008 | 03:55 PM
ModManiac's Avatar
Ive got this problem also! I get alot of compliments on my gauges but dang they are bright!!! Autometer offers a dimmer box and its around 40 bucks through summitt, give them a call and that should be your fix.
Old 02-07-2008 | 10:01 PM
omaharam's Avatar
I used a rheostat (voltage regulator) and then wired that between the gauge and the fuse box. Same as the Autometer mentioned above, but cheaper.
Old 02-07-2008 | 10:37 PM
tcr's Avatar
tcr
Go to pepboys and buy the bulb colored covers, I put blue ones on mine and they look cool plus they're not so blinding. They also have other colors, red, green, etc...
Old 02-09-2008 | 12:04 PM
BLACK PEARL's Avatar
Auto Meter had a Dimer switch for around $30.
You can get it at http://www.dieselmanor.com/autometer/AM-9114_dimmer.asp or www.dieselmanor.com under gauges
Old 02-09-2008 | 01:42 PM
Billm2004's Avatar
i had the problem too, i put a $.50 resistor inline.
Old 02-09-2008 | 05:01 PM
thanks guys, autometer dimmer ordered and on its way
Old 07-12-2013 | 11:46 PM
maddog1927's Avatar
What resistor did you use? I got 330 ohm .5 watt from Radio shack. I had to couple all 5 in the package together to get it close and its still too bright. I assume I need about a 2000 ohm resistor, or does going up or down on watt rating do anything?
'06 factory match pyro. Bulb is internal, no way to get to it.
Old 07-12-2013 | 11:49 PM
maddog1927's Avatar
http://www.radioshack.com/product/in...7&locale=en_US
or this??
Old 07-14-2013 | 05:54 PM
maddog1927's Avatar
3300 (3.3K) Ohm 1/4 watt resistor did the trick. $149 for 5 at radio shack.
Hillbilly Delux
02-07-2008 03:12 PM
Bradtothebone
11-06-2007 07:27 PM
ramcummins
01-04-2004 04:32 PM
Cumminsdude
11-12-2003 01:23 AM
rattle_rattle
0
10-29-2002 05:05 PM
