aurora mst
Not really
There is a VA Tech Engineer coming to St. L on Dec 1,2 for a special dyno event where he will educate attendees and demonstrate the C5. It will be a unique opportunity to learn "how to" use the software to get the most from your truck. There will be announcements on all the major Forums and as far as getting "Your" truck to have a custom tune,... it will be on a 1st come basis. This unit, as I'm sure you know, can do timing, duration and pressure. The instructor will have huge overhead projection of every mouse click so you can see "how to".
You can get a jump on the rush if you're interested by calling 636-451-4144 and ask for Keith and reserve your dyno slot. All those who are scheduled will get 3 dyno runs. The 1st will establish a baseline and will be with the factory settings. The following two runs will demonstrate the tunability of the unit and the power potential. The custom tunes will be at safe levels. To establish the overall viability of this product you will be asked to remove all power adders (downloaders and boxes), injectors mods, turbo upgrades, modded cp3s/dual cp3s etc are fine as they will differentiate themselves from others with higher baseline runs.
There will be refreshments available so make planning to attend for a very special dyno event with a level playing field as you will be competing against yourself and your previously known dyno results. So Take The Challenge!! There will be units available if you choose to purchase on site.
This is NOT the OFFICIAL announcement, but addresses your scepticism about the software availability.
Stay Tuned!!!
Stay Tuned!!!
Not quite, its ATS's version of the Variable Vane Turbo. Pretty cool concept and it looks as if it should work great. MST stands for Multi Stage turbo. You can read more about it here, http://www.atsdiesel.com/ATSWebsite/...rboSystems.asp or the thier how to section.
hotmod660
02-05-2007 03:02 PM
t-boe
17
12-09-2006 10:09 AM
sway825
10-26-2005 07:02 PM
