ATS twin turbo kit
Old 07-24-2007, 09:43 AM
Jethro6213's Avatar
ATS twin turbo kit
Who has this set up and how do you like it? Thanks
Old 07-24-2007, 10:33 AM
morkable's Avatar
There are a few members on here with that setup (dwiggs for one) but IMO they are over priced, you can get more turbo, better service, and more precisely what you want/need from Nathan at Idaho twins
Kevin
Old 07-24-2007, 10:34 AM
megacabrule's Avatar
Smile
i have the aurora 2000 and aurora 5000 and i love them.....quick spool up also very good on the bottom end.....not 2 bad on the top end either
Old 07-24-2007, 10:39 AM
Winner winner chicken dinner!
RyeThomas's Avatar
The box sets like ATS and BD are good, but having a custom set built for your needs/goals is another option that is better for some. I am pushing my BDs and could have saved myself alot of cash having custom twins built in the first place. I guess its all in what you want.
Old 07-24-2007, 10:48 AM
Idaho CTD's Avatar
Just considering compressor wheels the A2K is 58mm and the A5k is 71mm at the inducer. The stock turbo is 60mm on 04.5 and up trucks and both a S400 and a GT42 are 74mm. The A2K has a much bigger turbine section than the stocker which will make less back pressure for a given boost. The GT42 has a similar size turbine wheel as the A5K but it is higher flowing thus less back pressure for a given boost. The S400 has a considerably bigger turbine wheel (.5" bigger) and will make less back pressure and more power than either the A5K or the GT42 but it does spool a little bit slower. Just a FYI on turbo sizing.
Old 07-24-2007, 11:35 AM
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
nathan,
will have to come and see you when I get up there for christmas vacation. Am from McCall and going home to see family. Shane is going to make me spend a ton of money on this site!!
will contact my brother and send him your way for a set of your twins.
Old 07-24-2007, 11:37 AM
wap
wap's Avatar
Arent those the smallest wheels you can get in the S400 and GT42?
Cant you go to 80+?
Old 07-24-2007, 12:05 PM
Jethro6213's Avatar
Thanks guys, I was just wondering about them. I just want to get the right set up the first time. I was considering the BD twins but I don't know if they will be big enough for modded injectors and dual cp3's.
Old 07-24-2007, 01:13 PM
Idaho CTD's Avatar
Cant you go to 80+?
I was refering to box stock turbos. You can get the S400's as high as 88mm with 80 and 85mm in between. Right now you cant get the GT42's any bigger but it's coming.
Old 07-24-2007, 01:29 PM
Idaho CTD's Avatar
The dual S300 combo from BD will never make enough power to warrant dual cp3 unless you want to spray it. The biggest S300 (72mm inducer) available only flows around 90lbs/min. (like a A5K) but I dont even think the BD kit's is that big. About the most you could hope to make on 90lbs/min. is about 675-700hp in twins and realistically without a wastegate on both turbos it's probably closer to 625-650. The back pressure will get too high too fast to make more.
Old 07-24-2007, 02:24 PM
RyeThomas's Avatar
Thats why If need be I say go customs, not of the shelf twins. Again Ive had to learn the hard way. And now Im trying to save 10K for dual cp3s and new twins .
Old 07-24-2007, 02:42 PM
drillpipe's Avatar
X2. Mine work great.
Old 07-24-2007, 02:57 PM
338Lapua's Avatar
ats twins
I don't have many mods yet, but reading here and elsewhere I've learned ALOT!!! You guys have tried it, liked it or not and talked about it, that helps guys like me learn what might work for my needs.
I want twins, but I don't need 800hp, would be nice tho!! After I get the FASS, FS2500, and the TST/smarty, or C5, it'll be twins.
I talked to Rip at Source the other day and he suggested 62/12 or 64/12 over an S400. I have a DD, and tow my 5'er and want a quick spooling setup. Haven't talked to Nathan yet, but will. Was originally gonna go with a BD or ATS set, not now. Who knows, I may NEED 800hp down the road.
Old 07-24-2007, 03:38 PM
wap
wap's Avatar
Thanks for the info, I thought you could go quite a bit bigger but wasnt sure, now I know.
Is there any advantage to a GT42 vs an S400? Around the Dodge sites it seems the S400 is prefered but thats just what it SEEMS like to me.
Old 07-24-2007, 05:16 PM
jwb600's Avatar
I would like to add something to my aurora 5k if the price was right. Im mainly on the street all the time would like to have less lag
Quick Reply: ATS twin turbo kit
