ATS or BD Twins
ATS or BD Twins
Without price being a deciding factor, which setup is better? Also, does anyone have a pic of the ATS system installed?
I've also considered the Piers and Poole setup. However, Piers has about a two month wait and Poole seems to be lacking on the customer service end of things. I don't want to have to beg someone to take my money!
Which set
What about spooling on ATS Twins and dyno numbers
As we all know, it is the function of all the piece parts of this bombing thing that give you a total result. Having said that, as some of you may know I have had a problem with popping when I stack the TST with the CLDL even when the DL is turned to it's lowest level and when the TST is also turned WAY down. I do not however have that situation with the TST/EZ. I would say the concensus from the members has been that I am running out of fuel, hence CP3 mod is still needed. To compound that problem the systems on my 04.5 make the ecm defuel at two critical places for optimum performance,...out of the hole (just dumping on it without boost braking) and at the 3rd/od shift. The 3rd/od shift I have overcome with my ATS Commander. Out of the hole was outstanding with the stock turbo but when you have a set of twins that goes from around 38psi boost (stock turbo) to 62 psi boost on the ATS twins you magnify the CP3 problem.
Hopefully this has set the stage for answering the 1st question. With the twins the out of the hole performance is decent,...not great,... if you give it half or a little more throttle and then slam it! I'm told that will go away when the CP3 goes on. The rest of the run is very strong. If I boost brake it, then it is a slingshot. Around town your not putting your foot through it at every stop light so a moderate foot gives you a no lag nice take off.
On dyno numbers for the ATS Twins,...nope haven't done any for over a year and didn't have the twins or half of my mods that I now have at that time. If the CP3 mod allows me to use the CLDL on either tow or performance mode I have no doubt I will be over 600hp when I dyno. There is a dyno day for charity coming up here soon and if I have the CP3 on the truck I will dyno and post those numbers.
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
smittybuilt
01-08-2005 11:32 AM
