ARRGH! Blown Turbo Gasket!
Old 05-24-2009 | 10:15 PM
bigwheels94's Avatar
Decided to go for a spin today, & while passing a mini-van my turbo gasket blew out. It was the one HTT sent with the new turbo. Lost one of the nuts for the flange bolts too. I was only 50 miles from my house, but luckily my friend was able to get to me, & tow it home. Guess what I get to do tomorrow?
Old 05-25-2009 | 03:02 PM
DENVERDODGE04's Avatar
wow, never seen one blow out. I heard of them leaking from warped flanges... 1 hour job not to bad......
Old 05-25-2009 | 03:52 PM
I don't know if the nut came off 1st. Or he gasket blew out, & I lost the nut after. Worst thing is, it's Memorial Day, & no parts stores are open around here. Best thing is ,week before last I was 350 miles from home with my camper, hunting turkeys. Glad it didn't blow then.
Old 05-25-2009 | 11:27 PM
Spooler's Avatar
Yeap, that wonder graphit piece of junk that is in my toolbox I refused to install....LOL
Old 05-26-2009 | 01:13 AM
Yeah. I was really when I saw what the gasket was made of. Not even a wire reinforcement. More like heater hose with silver wax on it. That won't happen again.
Old 05-26-2009 | 08:02 AM
Jason_K's Avatar
i had the exact same thing happen to me about a month ago, i even lost one of my bolts too! the only thing that was different between me and you is that i was only 5 miles from my house and i limped it home
Old 05-26-2009 | 10:53 AM
Brian Lent's Avatar
Make sure you get the bolts as tight as you can, I double nutted the ones I could because they came loose twice. Can't go wrong with the stock style metal gasket.
Old 05-26-2009 | 12:43 PM
I called everyone I could find in the phone book, & nobody has the gaskets in stock! They should be here in the morning.I'm getting them from my cummins dealer.
Old 05-26-2009 | 09:25 PM
Spooler's Avatar
Call HTT. They have a new metal one now so I hear.
Old 05-27-2009 | 01:02 AM
I found a set. Luckilly I live only 1 hr from DDP in Monroe Wa. They had the Cummins gaskets in stock, & after a few hours on the road,(in a borrowed car), & then a few more hours under the hood, I'm back on the road again. I have another set coming in tomorrow, so I'll have some spares.
This was the first time my Dodge has let me down, but it wasn't it's fault. I'll never have another one of those graphite gaskets on my rig again.
Old 05-27-2009 | 11:25 AM
CamperAndy's Avatar
Just curious did you use a torque wrench on the failed gasket?
Old 05-27-2009 | 02:59 PM
I had the turbo installed by a HTT dealer near me, & I know there is no way to get a torque wrench on all the bolts anyway. I'm sure that the reason it failed was a lack of support. It was the old graphite gskt with NO METAL REINFORCEMENT. I see now that HTT no longer uses it, & has gone to the OEM steel one from Cummins.
Old 05-28-2009 | 03:39 PM
paulb's Avatar
You should get one from HTT for the stainless exhaust housing turbos. They now have one that is made of the same material as the stock gasket, but is larger to fit the stainless housings better. The stock Cummins gasket is hard to keep sealed, because it's just a little to small.
Paul
SeanB23
02-17-2009 08:07 PM
jmccart
14
08-01-2008 12:46 AM
bc3
11-19-2007 11:17 AM
wood_n_soldier
17
09-24-2004 01:15 PM
soopertrooperII
01-13-2004 12:28 AM
