ARP stud ????
Old 06-12-2009 | 08:58 PM
RAMRODD's Avatar
ARP stud ????
The studs are in. And I want to enter a sled pull tomarow. is this a ok thing to do? No time to put enough miles on to justify doing a retorque. Is this a big
Old 06-12-2009 | 09:33 PM
TrkEnvy's Avatar
How much peak boost you think you will push during the pull??
Old 06-12-2009 | 10:06 PM
RAMRODD's Avatar
I plan to keep it a little under 60
Old 06-12-2009 | 11:24 PM
JOESHTRDDSL's Avatar
I think you will be fine. Keep the timing as low as poss and try to keep the boost at or under 60psi and I don't think you will have a problem.
Joe
Old 06-12-2009 | 11:35 PM
OldSmokey's Avatar
If you didnt pull the head, and replaced one at a time. I was told to torque them to 125, back the nut off, and repeat the process and you should be good to go on the 4th retorque. This is what the instructions stated with my studs. I plan on checking mine tomorrow after a week of driving.
Dshiftff
0
07-29-2006 09:55 PM
one54ton
07-16-2006 04:29 PM
Tiger Rag
33
04-04-2006 08:37 AM
AK RAM
02-15-2006 03:30 PM
AK RAM
16
10-16-2005 05:35 PM
Quick Reply: ARP stud ????
