arp head studs without changing gasket
So were having a debate here;
Can you put in ARP head studs without changing your head gasket?
we have only done it doing the headgasket.
yes, and they have been known to hold 80 pounds of boost for quite a while, a certain 1298 hp tuck down in MD has used the stocker for about 60 thousand miles, runnin twins, nos, near /at/ over 80 psi.
Richard
You botton tap the holes to allow the stud to go into the block further and insure that the treads on the stud are in full face contact with the treads in the block. Also, oil will work into the bolt holes over time. Fluids do not compress well and in both the reason I stated above and this one. It is to avoid a false torque reading!!! Very important to do it right the first time so you do not wipeout a head gasket.
Richard
Richard
pwrtripls1
03-10-2011 12:12 PM
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
