Arctic Air Twins
Arctic Air Twins
what do you guys think of this kit? Is my Quad box on the 100 hp setting goin to give it enough fuel to make it a fun daily driver and tow rig? I am thinkin of havin DDP hone my sticks (75 HP) maybe thats a better plan???????
I can tel you from dealing with Chris from Relentless diesel in the past, that his work and products are all top notch, and you would be hard pressed to find any better customer service in the buisness.
Rick D
Rick D
I second the praises of Chris. He did my tranny and was great to deal with. I saw the arctic air twins on a truck and they were a really clean install. I was very impressed. The same truck is running mid to low 12's in the quarter mile and during the week working all day long.
Brad
Brad
i was also wondering about this kit as im gathering parts to fulfill the performance side of my truck. i have been reading all of the arctic air twins posts and they seem to work pretty good. some say the drive pressure would be to high and others say its ok(using the stock turbo). but i wonder if you could have the best of both worlds? buy the arctic air twins and send you stock turbo off to piers and have them do their pdr modified stock turbo service. i believe they open it up some more for the towing croud, then agian im not really sure? just an idea.
I highly recommend calling Chris and talking to him.
He doesn't even know what BS is, he will tell you straight.
Michael
http://www.relentlessdiesel.com/
Michael
Chris is a great guy. He installed the valve body on my tranny and will most definately been installing my full tranny soon hopefully. He built two of my friends tranny's and they were great. Chris is an awesome guy to deal with.
Just talked to Piers. They said with the Quad box my stock turbo will not last. They will not warranty the mods they do either with my setup. They also said that If I go to the Artic air twins my stock turbo is good as is and that it will not be working all that hard in that setup.
If all you are going to run is your quad box and some injectors you are not going to need twins. You might be at 425hp with that setup which is definitely on the low end of the power range for twins. Your best bet would be to pick up a BD super B turbo and run it as a single, then in the future if you have more power or really think you need twins, then you can buy their twin upgrade kit which includes everything except the super B (which you would already have). JMO
I'm really interested in this set as well....FASS is next then hopefully a set of Artic Twins. Haven't read anything negative about Relentless Diesel, and it sounds like a great bang for the buck system.
Jeff K I spoke with chris today via email and he estimates Ill be making about 485 hp with the twins quad box and 90hp sticks. He also said that I will be pushin more than enough fuel for the twins.
Ramirezh
34
11-10-2006 12:38 PM
abc4yew
19
04-17-2006 02:20 PM
