arb air lockers
arb air lockers
I have an 07 ctd srw, aybodyknow what size diffs it has and if arb even makes airlockers for it yet? i heard rumors that people have been waiting a long time for lockers, but was unsure what diffs i even have so didnt know if it applied to me
Im not sure but I think it a aam 9.25. Not sure about air lockers but Ox Lockers are tuff and cable actuated.
http://www.ox-usa.com/ox/
I have the aam electric locker in my 05, it was a direct fit no grinding of the case or anything. And the only thing else that I know available for the 9.25 is the Eaton e-locker, but you have to grind on the housing to make it fit.
Personally I like the e-lockers, no air compressor and seems less complicated.
I haven't had any problems with mine and have used quite a bit at truck pulls.
Yes, it is a pretty easy job because your just switching carriers and the housings have adjustable bearing colars. Just takes a little time because you have to pull the hub bearing assembly's out to remove the axle shafts. The hardest part you will find is getting the hub bearing loose.
Thanks
Dustin
Thanks
Dustin
I wish Detroit would make a normal ole' locker. It would be fine w/me since besides a few snow trips a year, I only use my 4x4 for mudding after it rains (and reversing a trailer w/an aftermarket clutch).
Thanks
Dustin
Thanks
Dustin
