ARB 9.25 Front Locker Installed!!
Well just drove my truck home from TST in Columbus, Indiana.
I will say its a relief to finally have a locker up front.
TST did a great job with the install which included:
Mounting and plumbing of the air compressor.
Scott @ TST also did the complete install of the unit and mounted the KEWL ARB switches in the cab!
Hopefully this gets more power to the ground when I am hooking!
Nick,
The locker itself retails in the $1k area...Labor of course is extra but worth it.
If you want exacts call them and talk to Mark or Scott.
This is a bolt in designed for the the Dodge application. NO GRINDING!!
Scott mounted the compressor up by my air intake area in front of my passenger battery.
finally someone comes out with a locker specifically for our aam 9.25 axle. i think this is the first one that ive seen that didnt require grinding. others ive seen are made for the gm ifs 9.25 front axle but they work in our axles with some grinding. as soon as arb has a rear locker for my 11.5 rear ima get em!
You may not have to grind the housing with the ARB, but you do have to screw with the compressor and airlines.
