anyone using di pricol guages??
Originally posted by MAJORCOMMOTION
Got'em and like'em. Wish the EGT and Boost would light up like the tranny gauge, but that's my only complaint. EGT is fast pre turbo.
Is your pyro needle not lit very well, and the dial slightly dark at 800*? Both the LED and light work on mine...
ckennedy,
Been selling them since 1998, low defective rate, good customer service and excellent accuracy. Lots of folks don't know it but they make OEM parts for Cat, Komatsu, Euclid, and John Deere too. We stock all the line and have the mounts and such for them as well as GUARANTEE all of our prices to be the best.
Mark @ DPPI
Mark @ DPPI
had mine for over a year. My EGT is pre-turbo and reacts pretty fast. My only complaint is the lighting. Trans temp is great but boost and EGT could be brighter.
Lucky you. I just finished my install and write-up.
Details & Photos Here
So far, good gauges. Couple of complaints... as above... a little dim on the EGT gauge and its needle at night. Excuse my night photo on the install as I first installed the EGT without hooking up the light bulb so it's dimmer than actual. I'll update it with a new photo soon.
Second complaint was the wiring... I had the temp probe wires come loose from the plug for the EGT gauge and there was a short in the splicing of the two wire pairs for the boost gauge. Geno's quickly sent me a replacement wiring harness for the EGT (outstanding customer service) and I repaired the short on the other myself.
Other than the wire problems... I'm very satisfied. The gauges both respond quickly, look very nice, and seem to be well made gauges.
I have their boost gauge...works great but the lighting on it isn't evenly distributed, I mean there are dark areas on the gauge for some reason but other than that I'd buy it again.
have had the boost and pyro since june. like them, however the pyro is starting to stick and will not come down below 600 degrees without a little tapping. wish i kept the receipt, i would call up the seller and inquire about a warrranty. other than that, love em.
I have Pyro, Boost and Fuel pressure, love them all they changed the Pyro to LED and you can see it alot better, have'nt had a bit of problems with them. Check out my photo gallery to see what you think.
nitrous
06-13-2010 11:17 PM
Dodgezilla
03-02-2006 11:15 AM
Mopar_Mudder
16
05-05-2003 01:00 PM
ATEAV8GN
12-13-2002 08:51 AM
