Anyone try the TRUX 2" levelling kit?
I was quoted about $500 for parts,taxes and labor to install one of these? they also said i need a wheel allignment after for $70. has any1 ever tried it? im a mechanic can i install this easily on my driveway? i have no garage.
does our 2004 dodge ram 2500 4x4 need 2" or 1.5" to be level
I put a 2 1/2" in from Top Gun Customz. It's pretty simple to install. It took me about 2 hours including rotating tires. If you've got jack stands high enough to hold the front end up from the frame you can get it done in your driveway.
With the front axle hanging at full droop you pull the bottom track bar bolt (some try to do it without this step, but it's easier if you do), remove the 3 nuts on top of the spring cup, unbolt the bottom shock bolt and remove the spring. You put the spacer on top in the spring cup and then reverse the process. No spring compressor needed.
if your a mechanic, shame on you if you pay somebody to install it. Took me about an hour with air tools. paying for an alignment cost total was about 180 bucks
