Anyone running a bigger turbo on a stock truck?
Old 01-02-2007, 04:43 PM
robert chilton's Avatar
As the title says. I want to upgrade my 04.5s turbo. The truck spends most of its time empty but does do duty pulling at max wieght. So I am looking at at something that spools well/close to stock but moves good air. I am looking at the II and HTT 62 series along with the 71 series. Any input is helpful. Also exhaust housing recomendations. Searchs didnt find much on a stock truck. One day a set of noozles may be in the future but stock for now. Thanks guys.
Old 01-02-2007, 05:10 PM
chw
chw's Avatar
go with II's 62 or 64 you will want the 62 if you want to tow heavy or often but you wont get the performance of a 64,if i was you i would get a 64, all around great turbo for lightly to moderately modified trucks that tow.
Old 01-02-2007, 05:22 PM
Forrest Nearing's Avatar
I would think on a totally stock computer controlled truck, you'll probably hurt performance more than you'll help it... get a programmer on there, and it's a whole different ballgame
Old 01-02-2007, 05:40 PM
C Schomer's Avatar
I did the muffler first and then the turbo. It really helped the top end. Instead of falling flat at 2200 rpm, it came alive. Craig
Old 01-02-2007, 06:35 PM
Thanks guys. I forgot to mention that I need to keep my turbo mounted exhaust brake.
I had a Quadzilla on the truck but I pulled it off a few months ago. It worked flawlessly for around 8 months. After the dealer did a flash I started having issues with the CEL. I didnt have the time to play with it so I pulled it for now. Been toying with putting it back in and seeing what the problem was. Got a little free time now.
Right now the stock muffler is straight piped with the kitty hanging on. I think that the exhaust is good to go. It definatly runs better this way. Min drone and doesnt make enough noise to **** of the neighbors. Gained 2 MPG on the interstate.
Forrest the problem with the turbo is the exhaust side. It is similiar in size to the HY35 with a 9cm housing. It doesnt take much to hit over 1000 degrees. With a load on her it is a real chore trying to just get going without sustained EGTs of 1400 degrees. RPMs actually raise the EGTs!! Anything over 2200 has you lifting off the go pedal with a trailer. Quick spool starts cooling the temps but that tight housing is killing the middle RPMs.
I am also looking at a set of noozles for the truck but I believe that it will be atleast another 6 months till I have the extra cash for those.
Any votes for the HTT?
Old 01-02-2007, 07:35 PM
oh I'm sure the stocker is restrictive, I just didn't know how it would feel down low without a programmer to give a little pre-boost fuel... I guess you could unplug the map sensor
Benson's Avatar
I have the HTB2 from HTT and it works great for me. My truck is not totally stock but the only fueling mod is a Diablosport Predator and I usually keep it on the tow setting. Mine is the 62. Seems to spool about like the stocker but provides much more on the high end. I don't think I would want to go bigger if you tow a lot. Still moves quite a bit more air than the stocker.
Old 01-02-2007, 07:47 PM
morkable's Avatar
I recommend the sps6280, I have ran this turbo with no fueling, just exhaust and intake. It worked excellent, very little lag, and I couldnt get the egts up over 1200 no matter what I tried. Even with heavy fueling I havent got it up to 1300 pre turbo,, love that turbo, and it will work with your exhaust brake too
Kevin
Old 01-02-2007, 08:06 PM
Morkable which turbo housing is that? the 12 or 14? I couldnt find it on their website.
Right now I am still looking for input from the 6spd crowd. I am concerned about the bottom end. I am also looking for some input on the htt 71 series if anyone has tried one.
Old 01-02-2007, 08:22 PM
morkable's Avatar
It is a 62 14, it would work excellent with a 6 speed. Even better than with an automatic. You would not be sorry
Kevin
Old 01-02-2007, 08:30 PM
BlueDually's Avatar
PM "dodgezilla," He put a htb2 12 on a nearly stock 6er
Old 01-02-2007, 08:36 PM
BigDave12768's Avatar
Another reason why to buy an 04.5 or newer. Bigger turbo and more top end power
Old 01-03-2007, 04:40 AM
Dodgezilla's Avatar
I had my HTB2 on the 03 and without the boxes turned on I really couldn't feel any difference in power. I did not drive this way too often so because mine was an SO so I can't really tell you any good info there.
I have the same turbo on this truck and even without the Quadzilla on the turbo makes a huge difference in power once it spools up. It actually feels like there's a box on there. I think you will be very happy with this upgrade. The price is right too on the HTB2s.....
Old 01-03-2007, 04:46 AM
Dodgezilla how is your initial spool up compare to stock? I have a 600 so it should act about the same as your new truck. I am worried about the day to day intown under 2000 RPM.
Old 01-03-2007, 06:31 AM
Dodgezilla's Avatar
It seems about the same as stock until it starts spooling up then you can definitely feel the extra power. I think I have a sticking wastegate issue right now so I may be pulling the turbo off this weekend and I'll get a better idea of the difference between the two with my current setup.
Quick Reply: Anyone running a bigger turbo on a stock truck?
