Anyone With Pics of Dual Steering Column Mounted Gauges
I'm getting a fuel pres. guage to go along with my tranny temp guage and I can't decide on the dual steering column mount or the full A-pillar replacement mount. I've seen and like the pillar mounts, but haven't been able to come accross anyone using the steering mounted ones.
Originally Posted by Nate-03 D
RamWheelsBy4- Where did you aquire the pillar mount for that?
i have the dual mount pod. i did not like the velcro that came with it for securing the pod to the steering column. so i used two stainless steel screws to bolt the pod to the steering column- plus i used a couple of stainless steel washers in between the pod and the steering column , so i could raise the front of the dual pod mount-so i could have it positioned just they way i wanted it. i don't mind the screw heads being exposed. it is an aftermarket accessory anyways and the screws really look like they belong there. kind of makes it stand out more.
HD, what kind of gauges are you running? I can't tell if they are Isspro or DiProcall. It's like they were made to match the factory style, and I've been told those were the two that match the closest. Also, does the mount color match close enough that you didn't have to paint it gray?
Streetsmoker I am running the Isspro gauges, and I believe the dual pod holder is made by Autometer.
My steering column plastic is more like a charcoal / black color and it matched perfectly I didn't need to paint.
I got most of my stuff from Genos garage but I would look here on this site at the DTR store...they have gauges and pods. I don't have the receipt handy and can't remember the total cost...it wasn't too expensive nevertheless.
Thanks for all the info it's just what I needed to finalize my decission between the pillar or steering mount. I just put in my order at www.dieselmanor.com and got a pretty good price.
GotStacks
05-23-2009 01:08 PM
Billm2004
03-09-2008 11:58 PM
smokindog
02-04-2007 12:51 PM
53 willys
18
01-06-2007 07:44 PM
danshsss
07-08-2004 07:07 AM
