Anyone install firestone ride rite bags? #2299
Old 04-17-2009 | 07:49 PM
sallyman1's Avatar
anyone that installed this kit did you just let the upper bracket rest on the brake line tab on frame rail? or did u grind weld away and relocate it? just wondering if bracket will rest flat or not if you leave it rest on tab? (driver side only)
Old 04-17-2009 | 09:00 PM
sallyman1's Avatar
any1? this is kit #2299 firestone ride rite helper springs
Old 04-18-2009 | 12:15 AM
rustyracer75's Avatar
i installed this kit on my 03 and i did grind and relocate the braket. this is what i would recomend doing if you have a welder, the mount sits at an angle to the chassis if the tab is not moved. if you dont have a welder you could cut the bracket off and make a tab to rivit to the chassisand the existing braket, the line bends easily and only needs to support its own wieght, so riviting is acceptable.
Old 04-18-2009 | 05:15 PM
sallyman1's Avatar
yes. maybe even zip tying to the upper bracket also.
Tigger
07-03-2008 03:51 PM
markp
03-12-2008 05:22 PM
Sixpack
03-27-2006 09:19 PM
03CTDCO
19
03-09-2004 08:10 PM
pwabbott
11-25-2003 10:11 AM
