Anyone Else Have Trouble Making Boost When Its Cold Outside?
i am having trouble making boost lately, i can barely make above 20psi. its been cold these last few days and hasnt gotten above high 30's outside. i do notice a difference in the way the truck runs and makes boost when its cold outside, anyone else notice this?
i can get to 26 psi when working her hard empty on highway but mostly see 20 psi. Its -20 celcius today where i live and i have edge juice attitude. if i crimp line to wastegate I can hit 42 psi EASY>
Never had this problem.But I have had aftermarket turbo on it since the first month of purchase.Never ran a stocker in the winter.Still doesn't sound right.Does it do it even after the truck is good and warm?
madhat's monkey boy...
I think when it is colder out the charge air cooler is way more efficient. The pressure coming out the turbo is the same but the CAC condenses the air a lot more. Better quality air but at less pressure. Boost pressure is only 1/2 the equation, air temp is the other. I know my truck is more powerful at 30 PSI 15*F than at 42 PSI 85*F
I put money on it that its your wastegate actuator. Mine quit working about 6 months ago. Pinched off the pressure line leading to the wastegate and all problems were fixed. Been running like this for 20,000 miles and not another boost or turbo problem. I heard of this problem many times in the last few months.
do i have a pressure line going to my stock wastegate? i thought it was electronic.
Can someone show a pic or better describe this hose as I have had this same low boost issue since about mid December. Dealer says if I'm not getting a CEL for low boost or high boost everthing is fine. There is no spec listing that they can find on Dodge that says max boost should be 32 psi.
It would be easiest to remove you passenger side fender liner. Usually about 10 screws with 5/16" heads. Then you can easily feel under and back of your turbo for the hose.
