Anyone Else Have Pictures of Westach Combo Gauge At Night??
Thats MR Hoss to you buddy!
I've seen MikeyB's night time picture, but I was wondering if anyone else with the Westach combo gauge had night time pictures they could share or opinions on the lighting.
Right now, even though I'm not real pleased with appearance of this gauge at night, I'm leaning towards getting it because I can't find a better option to go with the SRT-10 pillar.
Opinions are appreciated.....pictures will get you $10 (+/- 10).
Thanks.
FrustratedHoss
Thanks.
FrustratedHoss
You don't have to go and do that. I'm just trying to get a feel for what this thing looks like at night. The picture you have in your gallery now seems a bit bright for my tastes.
What I REALLY like is the DiPricol gauge below, but they don't make a combo EGT/boost and I can't find a dual gauge pod that I like.
The brightness is adjustable. I just didn't know it at the time of the install. If I ever take it apart I will back the bulb away from the face plate a little.
MikeyB
MikeyB
you need to get someone to take a pic with their camera flash off, the guage face will show up white with the flash on and black (with lit up numbers) with the flash off at night
The light actually shines from the left side of the gauge, leaving the right side of the gauge just slightly darker. I don't find it too bright. I originally had mine hooked to the dimmer, but took it off because I like to run with the dash lights as low as possible, which left the gauge too dark. Now its on full 12v, but still not objectionally bright. I would do it over again. John
Hoss, get you a in console mount from Geno's for $26.95
http://216.167.41.9/CoastalData/show...D=1525&CATID=1
and the get some gauges from TST that look like great at day and night
http://www.tstproducts.com/gauge_kits_trial.htm
I would do that if the console mount was a dual gauge kit. Then again, I suppose it wouldn't hurt to add a fuel pressure gauge to the mix. I also wondered about how complicated of an install that would be. I don't have a clue how to get back behind the console where those gauges would mount.
Getting behind the console is easy Hoss. Pulled mine off to tap cigarrette lighter power. Remove the screw above the garbage bag hook, open glove box, then start pulling around the edges of the console. It will pop right off. Amazing how things are put together these days. Reminds me of the snap together model car kits. John.
Hoss, call http://www.quadzillapower.com/guages.htm I believe they have 2 or 3 guage setup
jmccart
12-09-2007 07:32 PM
jmccart
02-17-2007 02:29 PM
ffjb154
04-24-2005 01:50 PM
MikeyB
02-20-2004 01:51 PM
