Any suggestions on 1/2 fuel line from tank to cp3?
What are some ideas or suggestions for fuel supply line from tank to cp3?
My current setup is 3/8 pickup tube, 3/8 fuel hose to fass 150 pump and 3/8 fuel line to fuel filter housing then stock fuel line from fuel filter housing to cp3.
If I convert the entire supply and return system to 1/2" I will be spending lots of money with aeroquip to purchase aluminum fittings 8AN and 1/2 hose.
Consider this and let me know what you think....
1. Will the FASS 150 work and perform well with larger 1/2 pickup tube and 1/2 line all the way?
2. How could I keep the fuel returned in the cp3 for lubrication purposes cool? Should I run a return line to the tank instead of the fuel filter housing?
3. Has anyone attempted such a revamp of the fuel lines to 1/2 inch and is it worth doing to keep fuel cooler and supply more volume availability at the CP3?
Thanks
Thanks
1/2" fuel line
Funny I was just reading about this last night. Go to Relentless Diesels' web site www.relentlessdiesel.com and Chris addresses this and other things he and others have tried with little to NO results.
Corner?
Originally Posted by checkster
are they going to make you stand in the corner for the remainder of the class?
Well
I think I can use Out-of-here's set up from the f filter housing to the cp3 then grab some 8an x 1/2 fittings and 1/2 line and go from the filter housing back to the fass.
Im thinking existing 6an fittings in the 3/8 line brings the passage thru 6AN fittings down to 1/4 inch. Maybe the fitting size used on the 1/2 line will help with volume.
Its all a big project for fun anyway.
Jethro6213
19
07-11-2008 11:59 AM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
